TypeR swap ?'s
Old Apr 10, 2003 | 05:50 PM
JeremyL's Avatar
Default TypeR swap ?'s
ok now i know the B18C5 didnt get into production until 97 after OBD2, now if i have a 94 LS with OBD1 and i swap in a 97 B18C5 would i have to have a OBD2 ecu or could i use the ecu from say a 94-95 GSR or something similar? i dont like the idea of being on an OBD2 system and want to avoid that problem
Old Apr 11, 2003 | 12:43 PM
nsxmatt's Avatar
Default Re: TypeR swap ?'s (JeremyL)
You can use a obd-1 chipped p28 and that will work fine. The GSR ecu won't work since it looks for the secondaries that the Type-R doesn't have.
Old Apr 11, 2003 | 01:10 PM
Kamin's Avatar
Default Re: TypeR swap ?'s (nsxmatt)
the gsr ecu will technically work without a CEL but the vtec engages way too early on the R cams (4400)
best bet is a chipped OBDI to ITR specs.
Old Apr 11, 2003 | 04:28 PM
JeremyL's Avatar
Default Re: TypeR swap ?'s (Kamin)
what about just using a hondata or aem ?
mkeacura
Aug 26, 2013 11:07 AM
HondamanXxX
Aug 12, 2007 07:30 PM
mattcivic
Jun 18, 2006 08:57 PM
SilverEk3dr
Dec 24, 2002 07:48 PM
