i am puzzled.. no clue.Help
Ok so i was driving today, everything semeed fine. I pull into the driveway and when i get out i hear a hissing sound from under the hood. So i go to check and the little resevoir for the radiator fluid (overflow) is overflowing and spillign everywheres. My temperature gauge is way HIGH. The rad pipe going to the block is hot, but the lower one on the rad is cold. i THINK i get a code. not sure. i always had code 17 before, but it only blinks once also no. Oxygen? Let me know! gotta get this thing running AGAIN. i had nothing but bad luck so far!
man, i'm really sorry about all of your misfortune with that car. it seems like you have 2 or 3 posts on here every day about it. It sounds like your thermostat is stuck closed, its only about 5 bucks at a parts store, or go to honda if you'd like a more expensive unit. better luck to you, mang
B6tizzleHatch
Dec 4, 2006 10:55 AM
EG93si
Oct 6, 2005 02:18 PM
