passenger headlight is dead. blown fuse???
well this is for my little bro car. 93 ex. His passenger side headlights is not working.
-turn signal works
*headlights don't light up even after getting new blub.
-but the driver side lights up fine.
where is the fuse for it?
did he damage the ENTIRE PLUG harness or do you think it's just the headlight fuse
-turn signal works
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The AntiRice »</TD></TR><TR><TD CLASS="quote">try putting the OLD bulb from that sideinto the other side to see if it works. If that works then you KNOW its not thebulb rather the wireing/fuse etc. </TD></TR></TABLE>
Also pulling the fuse is a good idea.
Give people a chance to respond too....damn. You didnt even wait a minute.
hrmmm..... i was gonna say he has the ol civic with a bad ground problem, but you say the high beam works? check the plug for voltage with a digital multimeter. Its definitely not the fuse, as they are both on the same circuit. Definitely check the wires to the plug with a multimeter, if it has voltage, then its the plug.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">just go buy a new bulb, because the low beam part of your bulb is most likely burnt out. and even if it is, the high beam part will still work.</TD></TR></TABLE>
That's exactly what happened to mine. this is your problem. I had to settle for some "cool blue" crappy headlights since they were sittin around the room... savin up for some silverstars now.
Scott
Scott
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB »</TD></TR><TR><TD CLASS="quote">
Scott</TD></TR></TABLE>
well my bro did get new light blubs, but it still doesn't work. WTF....
i had a similar problem and it was not the fuse or the light bulb it was the socket, it had melted and the neg. wire came out and i had to replace the harness/socket it was a pain in the ***.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex i ITR »</TD></TR><TR><TD CLASS="quote">my plug went out on me before. I had to get a plug of a wrecked Civic to make it work. </TD></TR></TABLE>
Exactly what happened to my roomates car. 3 bucks at Autozone.
