building my sohc
Old Apr 10, 2003 | 07:20 AM
TheAutoboxer
Guest
Posts: n/a
Default building my sohc
i have a 99 dx, gonna build the block, fuel system, and get ready for a turbo.
These are from nopi for 397, with a 9:1 compression with a turbo on the way.. would this be the best.. also.. im doing a minime.
Piston Set of 4 - CX/DX/LX D16-Y7 1.6L SOHC non-VTEC - Bore 2.953 - Stroke 3.543 - Rod Length 5.394 - Grams 233 - Dome Volume +12.4cc - Compression Height 1.181 - CC's 34.6 - Compression Ratio 9.0:1 - use ring set 135+3026
Old Apr 10, 2003 | 07:24 AM
Spade's Avatar
Default Re: building my sohc (menkio)
No
If your going to do a mini-me then that will change your compression.
You need to get pistons for a EX since that is the head you will use and the compression will be off.
BTW, look for group buys or specials, you don't need to spend 400 dollars for slugs unless you plan on getting crazy with the power.
If so, go to goldeneaglemfg.com and get some sleeves, pistons and rods from them assembled.
Old Apr 13, 2003 | 04:51 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: building my sohc (Spade)
well, say i do the mini-me head, and ex pistons, will take turbo ok ? after i upgrade the fuel and igition i was looking for 10-14ibs of boost
Old Apr 13, 2003 | 07:34 AM
t0p_sh0tta's Avatar
It's possible with a good tuner.
Rooftop voter
Nov 2, 2008 10:01 AM
b18bEKcoupe
Mar 4, 2007 06:33 PM
Attoir
Dec 5, 2003 05:18 PM
D16Z6racing
Apr 22, 2002 02:38 PM
