code 23 ?
Old Apr 9, 2003 | 02:54 PM
91 SlEePeR's Avatar
Default code 23 ?
what is code 23 need to fix. b16a pr3 ecu
Old Apr 9, 2003 | 03:09 PM
Newman's Avatar
New User
Default Re: code 23 ? (91 SlEePeR)
Code 23 = knock sensor. Check your sensor and the connection. Might need to re-run a shielded wire from the knock sensor to the ECU (into pin B19 on the PR3 ECU)
Old Apr 9, 2003 | 04:16 PM
Kataku2K3's Avatar
Default Re: code 23 ? (Newman)
Just to add a bit more... If you need to add this KS line or for some reason it got disconnected Newman is right... the nonOBD pinout is B19, but the OBD1 PR3 pinout is D3... Just incase you weren't talkin about the nonOBD PR3 to begin with... Good Luck!!
Old Apr 9, 2003 | 05:02 PM
Newman's Avatar
New User
Default Re: code 23 ? (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Just to add a bit more... the nonOBD pinout is B19, but the OBD1 PR3 pinout is D3... Just incase you weren't talkin about the nonOBD PR3 to begin with... Good Luck!!</TD></TR></TABLE>
Of course. But I saw his sig and it said "91 sleeper" so I figured he's got an EF, thus non-OBD PR3... heh
f22b2
May 3, 2016 07:56 PM
ExclusiveCRX
15
Mar 13, 2007 10:14 AM
StupidSlowRSX
16
Oct 5, 2004 04:26 PM
shadowstylz
Sep 17, 2003 06:05 AM
