Wierd Thermostat/Heat problem ..
Hey guys ...Im new also here so ..Uh what up
..Anywho there seems to be a problem occuring I just recently got this hatch and I've already started to make it perfect the way it needs to be
So heres the problem ..Not much heat inside the car after drviing around ...Heat will go 1/4 way up like its suppose to on gauge enless i turn the heat on then drops all the way down to cool
..Is my thermo stuck or whats the deal. Thanks alot
uhmmm whats the problem its coolin off more the heater is a second fan basically i have my heater blasting b4 i run because my radiator kept overheating. not a good thing but **** it works
The problem is it shouldn't drop all the way down to the C when I turn the blower on. Thats not right and I have a small amount of heat comning out when I do so.
xXx Justin xXx
21
Mar 19, 2004 05:26 PM
