del sol radiator troubles
Old Apr 9, 2003 | 11:48 AM
phantom_sol's Avatar
Default del sol radiator troubles
my del sol sprung a leak. i was wondering if i could use a del sol vtec radiator instead of the del sol s radiator. can i use my old hoses? also are the fluidynes half size or as large as itnegras. woul di have to sacrafice a/c for it? any input is greatly appreciated
Old Apr 9, 2003 | 12:35 PM
leprechan117's Avatar
Default Re: del sol radiator troubles (phantom_sol)
ok, fluidines are the correst size for the car. if its a del sol radiator itll be 14 inches wide, or whatever it is. if you order an integra radiator, itll be twice as wide, and you could no longer a/c. any 92-95 civic radiator will fit. i believe that the Vtec radiator is actually better, cauise its dual core, and twice as thick, and yes, itll fit as well.
Old Apr 9, 2003 | 01:16 PM
ill phil's Avatar
Default Re: del sol radiator troubles (leprechan117)
Yes, dual core Del Sol VTEC will fit and would be better cooling wise. The Fluidyne is half sized as is the Civic one if you get it for a Civic and full size if you get it for an Integra.
Old Apr 9, 2003 | 02:41 PM
MixdCrix's Avatar
Definitley go w/ the VTEC sol radiator-it does have a thicker core and
makes you think about actually havin a DOHC Vtec part in ur car! Id replace
the hoses while u were at it NEway. The integra rad-a nono....
and the 92-5 civics are a nice fit as well. My $.02-worth half that.
Old Apr 9, 2003 | 02:43 PM
flip b18b's Avatar
Default Re: del sol radiator troubles (juicnslo)
i agree go with the dual core vtec radatoir
Old Apr 9, 2003 | 04:08 PM
Default Re: del sol radiator troubles (flip b18b)
i think i'd get the vtec.... i'm planning to do a swap sometime (as i have said many a times) 9_9 but also with hoses.... would the hoses work on a b-series as it does with the d? i thought theyed be different.... unless i'm mistaken. cause the hoses look old anyways.
Old Apr 9, 2003 | 04:14 PM
cccya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip b18b &raquo;</TD></TR><TR><TD CLASS="quote">i agree go with the dual core vtec radatoir </TD></TR></TABLE>
Old Apr 28, 2003 | 12:31 PM
slcxow's Avatar
Default Re: del sol radiator troubles (ill phil)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ill phil &raquo;</TD></TR><TR><TD CLASS="quote">Yes, dual core Del Sol VTEC will fit and would be better cooling wise. The Fluidyne is half sized as is the Civic one if you get it for a Civic and full size if you get it for an Integra.</TD></TR></TABLE>
Is the del sol vtec dual core going to directly bolt up to a EG hb with a B16? thanks.....
Old Apr 28, 2003 | 12:44 PM
Default Re: del sol radiator troubles (slcxow)
del sol vtec has a b16 engine the si came with the d16 if that was what you were wondering. the del sol vtec radiator will work fine. i even think you retain the vtec hoses and it fits properly.
Old Apr 28, 2003 | 12:46 PM
B_CRUZ!'s Avatar
if you use the vtec radiator, the inlets would be too big.
Old Apr 28, 2003 | 05:53 PM
Default Re: del sol radiator troubles (BCRUZ)
for a b16? ......thats a little confusing
seoul-child
Sep 7, 2006 11:06 AM
the soL that could
12
Mar 25, 2006 03:58 AM
asmallsol
Nov 22, 2003 05:02 AM
egciviccx
Mar 28, 2003 11:37 AM
whagkangmakulet
Mar 19, 2002 09:04 PM
