Metal Headgasket for d16a6? WHich one?
Old Apr 9, 2003 | 08:53 AM
cottagecreep's Avatar
Default Metal Headgasket for d16a6? WHich one?
Sorry, I know this is sooooo simple, but I am leaving in like 10 minutes, and can't remember exactly which oem gasket to use as a metal A6 gasket. I think it was the Z6 gasket, can anyone confirm this? Thanks, sorry for the wasted space. Damn search button
Old Apr 9, 2003 | 09:01 AM
keithv's Avatar
Default Re: Metal Headgasket for d16a6? WHich one? (cottagecreep)
z6.
bring your old one if you can to make sure its an exact match.
Old Apr 9, 2003 | 09:04 AM
slowman's Avatar
I took way too long
doesnt that also act to raise the compression? i'm going to honda today, i might pick one up!
Old Apr 9, 2003 | 09:14 AM
DJ_SaNdOz's Avatar
Default Re: (slowmanEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowmanEF &raquo;</TD></TR><TR><TD CLASS="quote">doesnt that also act to raise the compression? i'm going to honda today, i might pick one up!</TD></TR></TABLE>
yes,i think that it raises comp by like .2
slowman's Avatar
I took way too long
Default Re: (dj_sandoz)
thank you, anyone know the price?
Old Apr 9, 2003 | 09:26 AM
zCivic's Avatar
I thought that the Z6 was still a composite head gasket. Y8 is the metal one and that will raise c/r barley enough to count though
Old Apr 9, 2003 | 09:34 AM
keithv's Avatar
Default Re: (zCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zCivic &raquo;</TD></TR><TR><TD CLASS="quote">I thought that the Z6 was still a composite head gasket. Y8 is the metal one and that will raise c/r barley enough to count though</TD></TR></TABLE>
i guess we'll find out for sure soon enough.
info from my convo with slowmanEF:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
(1:12 PM 4/9/2003) slowmanEF: does the z6 give higher compression? the HG is what im talking about.
(1:23 PM 4/9/2003) breaka_1_9: i wish i could find the d series info sonny has. basically you take his info and plug it into the c-speed compression ratio and it lets you know what the compression is.
(1:23 PM 4/9/2003) breaka_1_9: here is the c-speed compression ratio calculator. its easy with bseries since its all ready setup for it...
http://www.c-speedracing.com/h...c.php
(1:29 PM 4/9/2003) breaka_1_9: here it is:
http://www.muller.net/sonny/cr...t.gif
basically just plug your info into the c-speed calculator and get a results.
(1:31 PM 4/9/2003) breaka_1_9: so basically 9.1 vs 9.3 (with the z6 gasket)
Old Apr 9, 2003 | 09:35 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
i have the y8 HG. it bumps comp by like 0.2. it cost me like $20...were the z6 is like $40. like with everything else its not a perfect bolt-on...i ground the coolant passages out a little to match the stock a6 HG. i dont know if you have to, but i did. other than that its a good swap...no more scraping HG material.
Old Apr 9, 2003 | 09:54 AM
zCivic's Avatar
Default Re: (breaka_1_9)
breaka that list with everything is peachy for the D series gonna have to bookmark that
Old Apr 9, 2003 | 10:46 AM
jasonb's Avatar
d16z6 gasket is a 3 piece metal gasket. no composite material. direct replacement for the shitty a6 composite gasket.
Old Apr 9, 2003 | 10:48 AM
DJ_SaNdOz's Avatar
http://www.knology.net/~jediklc/D.htm
that's supposed to be for d series
Old Apr 9, 2003 | 12:15 PM
Cool guys, I went to honda, they couldn't tell me ****. (I didn't read any of these posts, I really meant 10min..haha) So anyways, it was a nice 1hr+ drive to have them tell me they will find out. Ahh well, so I have to call them tomorrow to make sure. I am putting everything back together for Turbo, thats why I wanted to go metal. I will post my final answer tomorrow. Cost of the Z6 gasket is $70can, and the whole kit for the A6 is $403can, which I am not buying btw
Old Apr 18, 2003 | 04:25 PM
Default Re: (cottagecreep)
btw, honda never got back to me... when I called, they had forgotten. I called uap napa, and they said the z6 head gasket from them was a 3 layer metal gasket. Hope that helps someone... the service up here sucks.
Old Apr 18, 2003 | 09:10 PM
EG8R's Avatar
Get a Z6 gasket.
Old Apr 18, 2003 | 09:15 PM
Ef Whore's Avatar
Default Re: (mr. skelly)
So the z6 HG needs no modifications the the passages? And it is .02? I gonna do this come summer if that's the case.
Old Apr 18, 2003 | 09:18 PM
USDM 4G VTEC's Avatar
nope the Z6 its a 3 metal layer gasket... and i beleive its a lil bit ticker than stock composite A6 ones... beleive someone else on compression.... i acntually know for a fact its a straight swap of gaskets for a better HG....
Old Apr 19, 2003 | 12:00 AM
Noahk's Avatar
Default z6/y8
The z6 is thinner, but it is a 3-peice metal gasket. The z6 and y8 are actually now the same. I have both in the garage.
Old Apr 19, 2003 | 12:31 AM
E-Town4229's Avatar
Default Re: z6/y8 (Noahk)
the a6 and z6 came with composite gaskets. it was common to have gasket failiure as the head would shift and wear the gasket down. honda updated it with a metal gasket and different head bolts. and yes they fit both motors. we still stock them at my dealership.
-Roger
EFstyle
Oct 1, 2008 08:17 PM
kuja396
Jun 15, 2006 02:02 PM
SPD DMN
17
May 2, 2005 08:30 AM
roycivic92
Jan 10, 2005 06:14 AM
Wes90civic
Jan 19, 2004 11:13 PM
