What kind of oil do you run?
Old Apr 8, 2003 | 06:40 PM
TwistedSI's Avatar
Default What kind of oil do you run?
Just changed the oil for the first time in my 99 SI. Can't believe I already put 3000 miles on it. Just out of curiosity, what kind of oil are you all running? I tend to stick with Texaco Havoline 10w-30. And how much should a b16 take? I put in 4 quarts and seems to be the right amount on the dipstick but thinking another half a quart couldn't hurt.
[Modified by TwistedSI, 7:41 PM 4/8/2003]
Old Apr 8, 2003 | 07:21 PM
TurboBumblBee's Avatar
Default Re: What kind of oil do you run? (TwistedSI)
mobil one synthethic 5w-30 4.3 quarts
Old Apr 8, 2003 | 07:22 PM
moondoggy's Avatar
Default Re: What kind of oil do you run? (Hybrid95CivicEX)
QS full synth 5w-30 (cause i can get it cheap) or else i would run mobil 1
Old Apr 8, 2003 | 07:27 PM
1 2 NV's Avatar
5-30 castrol GTX only.
Old Apr 8, 2003 | 07:29 PM
scdarksol's Avatar
3000 miles on your Si. Does that mean you didn't change your oil for 4 years? You really should change it every 6 months no matter what. But anyway I prefer Mobil 1 synthetic.
Old Apr 8, 2003 | 07:41 PM
Built to Spill's Avatar
el diablo
3000 miles on a 99. you must of spent a lot of time looking at it in the driveway. id take it in and let honda change your oil.
________
Racing 3
Old Apr 8, 2003 | 07:48 PM
94HybridEX's Avatar
Default Re: What kind of oil do you run? (8grandEG)
I think what he meant was that he bought the car used, 3000 miles ago...?
Old Apr 8, 2003 | 07:51 PM
94HybridEX's Avatar
Honda calls for 5w-30 and I use syn-blend. I *think* it's a bit over 4 quarts, but I don't remember exactly how much. I always do 4 quarts though.
Old Apr 8, 2003 | 08:02 PM
kommon_sense's Avatar
same here
Old Apr 8, 2003 | 08:04 PM
blkgsr03's Avatar
me 2
Jon Black's Avatar
Default Re: What kind of oil do you run? (kommon_sense)
Castrol GTX 10-30 or 5-30 for me.
Jon Black
Old Apr 8, 2003 | 08:09 PM
Shift!'s Avatar
Default Re: What kind of oil do you run? (Jon Black)
Castrol GTX 5-30 summer , 10-30 winter. Mobil 1 works too both fine IMO
Old Apr 8, 2003 | 08:15 PM
BauleyCivic's Avatar
Risky Business
Default Re: What kind of oil do you run? (Shift!)
regular mobil 5w30...have been using it for the last 2 years, dad was using it before then...car has 150,000 stock motor and clutch, doesnt burn oil, purrs like a kitten
to mobil oils
to honda reliability
Old Apr 8, 2003 | 08:28 PM
shermanyang's Avatar
it's been proven time and time again that you "CAN" lose power using thicker oil than specified. so by using 10w-30 you maybe losing power. don't quote me on this but it's what i've seen and heard from tuners using dynos. myself i use mobile-1 full syn. 5w-30 and for tranny fluid i use mobile-1 10w-40. works great for me
Old Apr 8, 2003 | 08:34 PM
Default Re: What kind of oil do you run? (thunderstyle)
honda-tech sucks www.ls1.com
Yeah...and so does your trailer park trash mom.
Old Apr 8, 2003 | 08:49 PM
girlyEG's Avatar
royal purple 10w 40 just cause i gots a hook up
Old Apr 8, 2003 | 09:21 PM
clm's Avatar
clm
Default Re: What kind of oil do you run? (girlyEG)
RedLine 10w30 with Mobile1 filter. No complaints.
Old Apr 8, 2003 | 09:26 PM
DarkCyde SI's Avatar
Default Re: What kind of oil do you run? (shermanyang)
i don't know about that one pal. where did you hear that? i use 10-30w mobil one synthetic oil because i live in california and since it doesn't get that cold here there is no reason for me to run 5-30w. but i may be wrong but it even says in my haynes manual that 10-30w is good through 30 degrees or something like that and it doesn't even come close to reaching that temp in southern cali
juicedricer's Avatar
Default Re: What kind of oil do you run? (clm)
mobile one full synthetic all the way with fram oil filter hahaha. the oil is still clean after 3 weeks and 9 passes down the track. went to synthetic and hitting 14's now in ls coupe
Old Apr 8, 2003 | 09:28 PM
mycivicstoo(s)low's Avatar
Mobil 1 synthetic 10w30. I may try 5w30 next time to see if I can tell a difference. It just gets so damn hot here I don't wanna mess with success.
Old Apr 8, 2003 | 09:32 PM
racerx707's Avatar
Default Re: What kind of oil do you run? (juicedricer)
mobil 1 syn 5w-30 w/ k&n oil filter, redline mtf tranny fluid
Old Apr 8, 2003 | 09:33 PM
jjdm327's Avatar
Default Re: What kind of oil do you run? (racerx707)
same, mobile 1 synthetic 5w 30
SlowazzGSR's Avatar
Old Apr 8, 2003 | 10:01 PM
X2BOARD's Avatar
Default Re: What kind of oil do you run? (94HybridEX)
On the teg and the hatch, I always use good ole Honda 10W-30...buy it by the case.
X2
Old Apr 8, 2003 | 10:03 PM
zeroracerh's Avatar
Default Re: What kind of oil do you run? (mycivicstooslow)
