how does ECG o2 simulator work
Old Apr 8, 2003 | 06:32 PM
genetsang's Avatar
Default how does ECG o2 simulator work
need to know how the ECG o2 simulator work and how is installed..... need to know before i purchase it... ECG o2 sims. were supose to be the best ones... so i dunno...
Old Apr 8, 2003 | 06:41 PM
577HondaPrelude's Avatar
Default Re: how does ECG o2 simulator work (genetsang)
The ECG is the only sim that works with OBD2 Hondas. That's why it's the best for us OBD2 guys, because it's the only option that I know of
The way it works is, it uses engin speed (RPM), and throttle position as it’s inputs. You get these signals from the existing sensors in your car. Then it calculates what the secondary O2 sensor signal should be for a car with a good cat.
[Modified by 57STS, 10:41 PM 4/8/2003]
Old Apr 8, 2003 | 06:59 PM
genetsang's Avatar
Default Re: how does ECG o2 simulator work (57STS)
oo gsr with obdII...... just want to know where it is installed to..... ecu??
Old Apr 8, 2003 | 07:17 PM
yes, you splice the wires going to the ECU. You can mount the unit anywere you have room, like under the passanger seat, you just have to run the wires is all.
Modified by 57STS at 10:21 AM 12/15/2003
Old Apr 8, 2003 | 07:23 PM
genetsang's Avatar
thanks
Old Apr 10, 2003 | 01:41 PM
ebp 99 si's Avatar
where can i order one
and how much
Old May 4, 2003 | 09:01 PM
ek9 ferio's Avatar
Default Re: how does ECG o2 simulator work (ebp 99 si)
how about http://www.defcon-racing.com are their 02 sim any good??
Old May 5, 2003 | 05:36 AM
TurboLude97's Avatar
Default Re: how does ECG o2 simulator work (ek9 ferio)
well i had one well i still have it but it was screwing up my car. the CEL didnt come on but it caused the car to back fire and would mess up the rpm signal. so i ended up cutting it out on my way home one night. and i found this out.... if you just cut the signal wire from the secondary O2 sensor (you have to cut it to install the O2 sim) and plug in your secondary O2 sensor (in the pipe is fine if there is a bung for it, or just wrap it in aluminum foil and put it some where that the heater wont burn anything. mines zip tied on right by the heat shield) so that way the ecu knows that the heater is working for the sensor then your check engine light problems will be eliminated.
madlion
Sep 21, 2007 05:59 AM
LostAndFound
Jun 24, 2004 05:56 PM
imonkie
Jul 20, 2003 07:19 PM
genetsang
Apr 9, 2003 05:19 AM
bmm89
Apr 7, 2002 03:08 PM
