Interesting tach question...b20z
Here's the deal. The b20z doesn't have the blue wire supplying the tach signal at the distributor. Instead it uses a signal from the ECU (A19 - NEP) for the tach. Well I am using the P75 ECU which doesn't have this "NEP" wire. What do I do for a tach signal?
my cluster will get the signal from the tach wire source. problem is, no blue wire on the distributor to feed the cluster, and no NEP wire from the ECU to feed the cluster.
damn! that simple? i was looking on google and they were talking about opoisolators, caps, hall filters and other things...i was like.....no...
thanks cheetah, as always you have me an answer.
Tyson
40
Jun 4, 2009 04:24 PM
ironchef25
16
Aug 26, 2004 06:55 PM
civicracer1993
Sep 17, 2002 10:53 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
