Checked compression
Old Apr 8, 2003 | 04:34 PM
Qwikrex's Avatar
Default Checked compression
I checked the compression of my B16. Numbers went like so.
cylinder 1: between 195-200
cylinder 2: 210
cylinder 3: 210
cylinder 4: 210
Do those numbers seem about right for a B16A2 with around 50,000 miles? Stock internals(except CTR intake cam)
Also, I followed the instructions from c-speedracing on how to do a compression test. As per their directions, I did the test with all spark plugs out at the same time. Another site had them doing each cylinder 1 by 1 with the rest of the 3 plugs in. Which way is correct?
[Modified by [VTEC]TL, 8:38 PM 4/8/2003]
Old Apr 8, 2003 | 05:49 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Checked compression ([VTEC]TL)
doesn't matter...you're only testing one cylinder at a time.
Numbers look good though
Drop a cap full of oil into #1 and try again...number should jump up to the others
Old Apr 8, 2003 | 06:21 PM
Qwikrex's Avatar
Default Re: Checked compression (Emerika)
What would putting in a capful of oil do?
Evs-One's Avatar
Solbros Owns Me
show you your rings are a little worn...seal em up
Old Apr 8, 2003 | 07:41 PM
Qwikrex's Avatar
ic. So the numbers look normal?
Old Apr 8, 2003 | 09:43 PM
stockegsix's Avatar
how and where can i get my compression checked
Old Apr 11, 2003 | 09:08 PM
xcivic_ex
Guest
Posts: n/a
Default Re: Checked compression (zzZZzzleeperCX)
take out all 4 plugs along with the ecu fuse so you don't get any fuel dumping into the cylinders get a compression tester(snap-on/mac tools.. any auto store basically) attach the correct thread pitch adapter screw into cyl 1.. have a buddy crank the car over for 4 revolutions with throttle wide open. repeat this process for all 4 cylinders. Like Emerika said if your compression raises after putting fluid into the "weak" cylinder then perhaps your rings might be a little worn. Or maybe some slightly burned valves not seating properly anymore.
it's a relatively easy process.
Jyankel
Oct 23, 2016 05:27 PM
jonyi27
Sep 21, 2013 10:55 AM
WhiteEJCoupe
Mar 19, 2010 03:35 PM
Tyteg
May 16, 2007 07:30 AM
Doogie Howser
Sep 15, 2002 05:26 PM
