broad EG question..
Old Apr 8, 2003 | 11:54 AM
jjdm327's Avatar
Default broad EG question..
ok, im looking to get an EG hatch... i was just wondering what all motor set ups some of you EG owners have to get me started on the right foot... So far, i have the money to do a B16a2 motor, and then ill have about another grand on the side to play around with.. i was looking into getting some cams, but i was wondering what you guys recommend.. also im going to start out with some basic lowering springs until the shocks on the car blow, so i can get some full suspension.. so any suggestions would deffinatly help.. thanks.
-jj
Old Apr 8, 2003 | 01:21 PM
civicmandx94's Avatar
Default Re: broad EG question.. (jjdm327)
IMO I would go with a B18C1, I absolutely love mine. For cams I would I would go with skunk2 stage 2's, but you will need to upgrade the head with springs, retainers, etc. Suspension I would go with either some ground control or skunk2 coilovers. Just make sure you research every part you want for your car. Research is the key to making the most out of what you have to spend.
Old Apr 8, 2003 | 01:24 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: broad EG question.. (civicmandx94)
don't get a b16 swap unless you plan on having a nice cheap daily driver.
All motor go with the GSR, some ITR valvetrain, and a SKunk 2 intake manifold
Old Apr 8, 2003 | 01:29 PM
jjdm327's Avatar
Default Re: broad EG question.. (Emerika)
ok, thanks, i was looking into the b16a2 cause its like almost a grand cheaper, and i could use that twords cams and gears... but if its that much more worth it to get the b18, then ill look more into that.. thanks
-jj
Old Apr 8, 2003 | 01:34 PM
kshymkiw83's Avatar
I am going with b16a Turbo........Depends on what you want to run!
Old Apr 8, 2003 | 01:38 PM
jjdm327's Avatar
Default Re: broad EG question.. (kshymkiw83)
well im voing to AZ in a few months, i wanted to do a turbo, but for the same price, i can get an all motor hatch, thats a little slower, but will run 10 times better and more efficiant... so thats what i decided to do, now its between the stock b18 for a while, or b16 modded right away.... we'll see what happens...
Old Apr 8, 2003 | 01:41 PM
IMO the B18C1 swap is definetely worth it. With simple bolt-ons you could out run B16's all day long.
Old Apr 8, 2003 | 02:29 PM
Mr. Thunderlips's Avatar
Mmmm...D16Z6.
Old Apr 8, 2003 | 02:42 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I like my B18C1. Midrange is nice with the stock intake manifold. Good for autocrossing because I'm usually in the middle, not the top... For now anyway... Maybe when I learn to drive better, that'll change.
Old Apr 8, 2003 | 04:16 PM
jjdm327's Avatar
Default Re: broad EG question.. (SkyeC)
do you guys think its worth it to spend another grand on the b18? or save that one grand, and hit up some skunk 2 cams/gears in a b16??
Old Apr 8, 2003 | 04:21 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Wait for the B18. Cams are nice for mid->top end but you'll still have the whack b16 bottom end pull.
Old Apr 8, 2003 | 06:47 PM
jjdm327's Avatar
ttt... anyone else have any opinions??? i would like as much info as possible before i spend my money.. thanks,
-jj
dcmonkey
13
Nov 24, 2008 07:47 AM
JDM.Jay
Suspension & Brakes
Feb 20, 2007 12:03 AM
Lookincrazy
Apr 19, 2002 08:45 PM
