Raspy exhaust
Old Apr 8, 2003 | 07:21 AM
m0t0rhead's Avatar
Default Raspy exhaust
Hey guys..
I have a Greddy Evo which I love. I added a test pipe from http://www.testpipe.com and ever since I installed it I have a really loud rasp at certain RPM points. It sounds gay. Anyone have experience with that ?
The one I bought is a non resonated one.. but Im not sure exactly why it rasps.. maybe it's from loose bolts causing it to vibrate ?? I dunno..
Anyway... I hate the rasp. Does not sound good. But I do not want a cat. Recomendations ?
Please don't tell me to buy a high-flow cat. I don't want one.
There must be something else I can do and keep the straight pipe or replace it with a better one. Thanks.. lemme know.
Old Apr 8, 2003 | 07:28 AM
Mover's Avatar
Default Re: Raspy exhaust (Escobar)
Anytime you drop the cat, it gets raspy unless your muffler isn't a straight-thru design.
Even though its not designed to, the cat absorbs some of the sound. The brick acts as a baffle to a certain degree.
I came across some test pipes in a British mag years ago that claimed to
absorb some of the raspyness.... I doubt they work without incresing backpressure.
Old Apr 8, 2003 | 07:34 AM
KGAccord's Avatar
Default Re: Raspy exhaust (Mover)
you shouldn't be running a straight pipe on the street anyways
Old Apr 8, 2003 | 07:57 AM
Nick M's Avatar
Default Re: Raspy exhaust (KGAccord)
i have a test pipe with a matrix straight thru muffler, no rasp, just loud as hell
i also have a 4-2-1 header, so maybe that eliminated the chance of any rasp? i have no idea
ive never been a fan of greddy exhausts
Old Apr 8, 2003 | 08:21 AM
hs2000's Avatar
I secound that, no need to kill the earth any faster then nessasary.
Old Apr 8, 2003 | 08:40 AM
Stew Pidasso's Avatar
Default Re: Raspy exhaust (hs2000)
When I see all pre-1990 domestic V-8s outlawed, I'll put my cat back on.
I had the same problem. I was told that with all the extra flow that the baffles in the muffler will vibrate because they are taking the full force of the exhaust rather than being dampened by a cat. I'm sure there are mufflers out there that will absorb the extra sound. Mine turned very raspy and they are straight through.
Old Apr 8, 2003 | 08:52 AM
KGAccord's Avatar
Default Re: Raspy exhaust (Stew Pidasso)
do you have any dyno proof to show a testpipe is worth it on a f22?
i know some h22 owners run a straight pipe and there are good mid to top end gains, but i don't see it being worth much on the f22. just buy a high flow cat, good flow and not as much rasp.
Old Apr 8, 2003 | 08:54 AM
m0t0rhead's Avatar
Default Re: Raspy exhaust (Nick M)
I wanted to get a header.. but I'm going turbo so I don't want to waste the cash.
Im wondering if the rasp is generated from the test pipe itself... like... if the metal is too thin... or ... if the flanges are loose and vibrating... or.. if maybe theres no gasket between the flanges causing vibration... weird.
Im thinking I should get a resonated test pipe... but I don't want to order from the same guy again.. maybe his product just sucks.
Old Apr 8, 2003 | 08:55 AM
m0t0rhead's Avatar
My friend has 0 rasp on his. He has a test pipe.
Old Apr 8, 2003 | 08:56 AM
m0t0rhead's Avatar
What are you ... a boyscout ?
Old Apr 8, 2003 | 08:57 AM
m0t0rhead's Avatar
Im installing a turbo.
Old Apr 8, 2003 | 09:23 AM
KTeller8's Avatar
Your test pipe should be something like this, testpipes.com tends to use a 'resonator" like item, that way they can sell them cheap
high flow cat or testpipe, hit me up and ill see what i can do for you!
Old Apr 8, 2003 | 10:32 AM
Mover's Avatar
The turbo will cut down the noise. I was referring to NA.
The cat muffles some of the sound. Removing it causes a more 'crisp' sound on a NA car (I heard 80s Firebirds with their cats removed as well as imports)
Kinda like turning up the contrast on the TV if you know what I mean
Old Apr 8, 2003 | 12:07 PM
KGAccord's Avatar
nowhere in your post did you mention that, i hope you don't have emissions testing. testpipe+turbo=bad emissions.
i'm no boyscout, but why pullute for an extra 1hp and noise. if you get caught you also face fines around 5,000 to 10,000k.
Old Apr 8, 2003 | 12:13 PM
crafty's Avatar
I had a Greddy on my civic....the resonator was scrapped so bad I had to cut it off ever since then
high rpms=raspy sound
The muffler shop I went to said they could add a resonator and it would eliminate it...
Hope that helps
Old Apr 8, 2003 | 12:34 PM
m0t0rhead's Avatar
It's more than 1 hp with a turbo and it's more than 1 with N/A. We have no emissions laws in FL but thanks for caring
KTeller8's Avatar
Default Re: Raspy exhaust (crafty)
Here in FL we have no testing and no "tree huggers" around here, where i am they dotn measure yoru car and dont go looking for stuff..
they will stop you on a dime just case though
Old Apr 8, 2003 | 12:36 PM
m0t0rhead's Avatar
Hope that helps
Nothing on mine is scraped and it didn't start being raspy at all UNTIL I put the test pipe on.
I appreciate your reply though thanks.
McLaner
Aug 29, 2011 01:18 PM
Inaccurate
Apr 27, 2009 12:13 AM
jdmludeaz
Apr 13, 2006 08:44 AM
gsrpwr
Aug 30, 2004 01:10 PM
integracivic94
Jun 5, 2003 09:09 AM
