Which Exhaust Setup
Old Apr 25, 2009 | 07:26 PM
Inaccurate's Avatar
Default Which Exhaust Setup
Im Torn Between 3
Do I buy
1) UniversalMuffler and Get it straight Piped
2) Buy a Cat Back System
3) Cat Back W/ Test Pipe
And Is there a noticeble difference in sound say if i got a HKS Univ Muffler str8 pipe'd
as oppose to a
The Same HKS but as a full cat back?
and recommendations as to what exhaust would be appreciated
ty
Old Apr 25, 2009 | 07:34 PM
sp00ledbseries's Avatar
Default Re: Which Exhaust Setup
At the least I would buy a name brand muffler. I don't suggest no cat or a test pipe though.
Old Apr 25, 2009 | 07:46 PM
Inaccurate's Avatar
i was thinking hks hi power ti or s2
why dont u suggest no cat
i just had emissions 5 months ago
Old Apr 25, 2009 | 08:00 PM
jdmwannabee's Avatar
you at least want to run a high flow cat.
no cat hurts performance.
test pipe will get you the best performance, but it'll probably be loud as heck.
high flow cat will fall short of the test pipe, but at least it's there and it won't be as loud. my suggestion is a catback with a high flow cat.
Old Apr 25, 2009 | 08:04 PM
Inaccurate's Avatar
so str8 pipe hurts performance?
sound too?
Old Apr 25, 2009 | 08:18 PM
Yes straight pipe reduces your back pressure. You WILL notice a power loss. Also it will be loud as ****
Old Apr 25, 2009 | 08:25 PM
Inaccurate's Avatar
didnt know that ty, so
Old Apr 25, 2009 | 09:08 PM
Inaccurate's Avatar
any suggestions for names?
Old Apr 25, 2009 | 09:20 PM
My favorite is apexi
Old Apr 25, 2009 | 09:26 PM
http://www.youtube.com/watch?v=vYAlI-mTK5I
http://www.youtube.com/watch?v=XCyuO...eature=related
http://www.youtube.com/watch?v=nhgwG3KWnBo
http://www.youtube.com/watch?v=C0lh1...eature=related
http://www.youtube.com/watch?v=xyxWeE4OcaI
Old Apr 25, 2009 | 09:48 PM
omnirage's Avatar
i recommend custom exhaust tubing and either an itr muffler or mugen. i just recently dropped my itr muffler (sounded okay, apparently restrictive though) for my new mugen twinloop. the mugen is damn awesome!
EDIT: HPPPPRAAAAAAAAAAAAAY DRUNKENS!
Old Apr 25, 2009 | 09:55 PM
Inaccurate's Avatar
spooled greatly appreciate it man
Old Apr 25, 2009 | 09:59 PM
No prob man just sitting here drinking a few beers and im in a good giving mood I guess you could say lol
Old Apr 25, 2009 | 10:11 PM
Inaccurate's Avatar
i can tell
Old Apr 25, 2009 | 10:35 PM
Ace2.0's Avatar
i use a cherry bomb turbo II muffler and 2.25 piping and it works out fine and sounds great
Old Apr 26, 2009 | 01:04 AM
I AM WEASEL's Avatar
Do you have anything to back up this claim? Any dyno graphs showing a loss in power when switching to a "straight pipe"? BTW, what are we comparing a "straight pipe" to?
Old Apr 26, 2009 | 10:54 AM
omnirage's Avatar
The backpressure myth is a joke. The whole point of an exhaust system is to clear the chamber and bring in a fresh mixture, not choke your motor...correct exhaust diameter is what you need to look at, not backpressure.
Old Apr 26, 2009 | 11:27 AM
SlammedDC2's Avatar
Semper Fidelis
I also very much enjoyed my twin loop, previously I had 2.25 with a "hi flow cat", with my new setup I will have 2.5 with a test pipe and my twin loop.
Old Apr 26, 2009 | 11:57 AM
racebum's Avatar
this is the correct answer. it's all about flow. team integra has a pretty good write up on pipe size and the effect on power. if anyone has doubts about this back pressure garbage. think it thought. combustion takes place, exhaust valve opens and the burned cycle is pushed out. if you did create "backpressure" the piston would have to push it out thus loosing HP. what you ideally want is the exhaust being pulled out of the cylinder in a scavanging effect. think about headers and why some make more power than others. it's all about the pull.
Old Apr 26, 2009 | 07:01 PM
I agree 100%, I was just seeing if sp00ledbseries had any evidence of his claim. I have said it before and I will say it again, for the most part, the header (ideally one tailored to your engine, not a generic one) will determine where your powerband is and will provide the necessary amount of backpressure; everything past the header is just restriction.
Old Apr 26, 2009 | 08:40 PM
When I had my hatch and went from a Z1 to a Z6 I was running the Z1 manifold for a couple of weeks. I bought a header did away with the header/cat and noticed a power loss. My buddy's coupe we noticed the same thing. From my experience if you have a stock motor you will notice a power loss
Old Apr 26, 2009 | 09:11 PM
Do you have any dyno charts to support this claim or was this tested on the scientific butt dyno?
Old Apr 26, 2009 | 09:15 PM
On the scientific butt dyno
Old Apr 26, 2009 | 10:47 PM
rhymeshark916's Avatar
Originally Posted by Inaccurate
Im Torn Between 3
Do I buy
as oppose to a
ty
What car and what is it use for? Go with ITR or CTR for it's own only if running a stock motor.
Old Apr 26, 2009 | 10:54 PM
rewsna's Avatar
i very much agree. i mean if anything, the straight pipe would clear the burned cycle out more efficently... common sense..
