ITR intake manifold?? Fitment issues.
I found a really good deal on an ITR intake manifold but I'm not sure what all I need extra to make it fit. I saw someone on here that made if fit with the b16 fuel rail, do I need to get the ITR throttle cable and bracket as well? I think thats what it is. I know I'll need a new gasket, but what else to make it work?
From: A place where stupidity runs rampant aka NorCal
No, all you will need is the stock Si throttle cable and a $10 HCP Engineering throttle cable bracket.
I would search for my how-to post but archive is still down, heres a link to pics of it installed.
http://www.f20c.com/albun15
To do it my way with the stock fuel rail, you will need to find an OBDII IAT and IAT harness plug to relocate the IAT in the intake. Otherwise you will have to spend the $120 (or whatever) for a new fuel rail.
edit - you will need a obd1+ IAC valve too
-Todd
[Modified by Count Blah, 8:41 AM 4/8/2003]
-Todd
you will need an EACV from a 92-95 civic si/ex or 94-97 del sol dohc vtec or 96+ gsr... i went with a 92 civic si one
you can use the stock b16 fuel rail but the fuel pressure regulator will hit the iat sensor so that will have to be relocated unless you get an aem fuel rail, i got one from a 94 gsr...
everything else will bolt up
if you get an acura integra 90-91 throttle cable, you can use the mounting bracket from your b16 intake
VinceVTEC
15
Sep 24, 2004 03:58 PM
