what fuel pump for my setup?
Old Apr 8, 2003 | 04:16 AM
Type RS's Avatar
Default what fuel pump for my setup?
what fuel pump should i use on my setup. i have a stock jdm itr engine w/ cam gears, jdm dc sports 4-1 header, apex'i n1 exhaust, aem fuel rail and a sard fpr. the car originally is an rs and it has about 100k on the chassis and i'm sure the fuel pump has never been changed out. i notice my car kinda lacking something so i'm gonna change this out just to see what happens. what should i get?
Old Apr 8, 2003 | 04:33 AM
BabyDaddy's Avatar
Default Re: what fuel pump for my setup? (Type RS)
no need for anything better than stock. I haven't priced OEM ones but you may end up cheaper with an aftermarket one. Check on a Walbro 195 lph in tank and compare the price vs. OEM.
Old Apr 8, 2003 | 04:59 AM
VTEC-DA's Avatar
Default Re: what fuel pump for my setup? (BabyDaddy)
OEM should be fine. But like he said, look at a Walbro 195. You can get them as cheap as $75.
Old Apr 8, 2003 | 05:11 AM
BabyDaddy's Avatar
Default Re: what fuel pump for my setup? (VTEC-DA)
btw...
If your doing this just because your car feels "tired," I don't see the point. You may just be wasting your money. Check for the obvious first (compression test would be my first check).
Old Apr 8, 2003 | 07:12 AM
BoM's Avatar
BoM
tuneup time, and also change you fuel filter.
Old Apr 8, 2003 | 08:39 AM
Type RS's Avatar
my compression is fine i just changed the head gasket out like a month ago. i'm using the stock head gasket and my compression was 250psi across the board. i'll check on that fuel pump and i think i'll just go ahead and get that tune up done. could that explain why i get such poor gas mileage. i get about 220 gallons to the tank. w/ today's gas prices that sucks.
Old Apr 8, 2003 | 09:01 AM
Stew Pidasso's Avatar
What's your fuel pressure at? It sounds like you may be running really rich and that could be killing your power
Old Apr 8, 2003 | 09:03 AM
BeerMan's Avatar
Default Re: what fuel pump for my setup? (Stew Pidasso)
check the voltage on the fuel pump, requires taking out the rear seats though
Old Apr 8, 2003 | 10:01 AM
RyanEJ8's Avatar
Default Re: what fuel pump for my setup? (BeerMan)
if the fuel pump has never been changed from an RS that means you only have a 79lph pump. the itr's come stock with a 135lph pump. just get a walbro 255lph, you can get them for $80 and if you ever decide to go boost or nitrous or anything you already have it.
Old Apr 8, 2003 | 10:03 AM
dfoxengr's Avatar
Default Re: what fuel pump for my setup? (BoM)
fuel filters that are bad kill performance
Old Apr 9, 2003 | 02:52 AM
Type RS's Avatar
Default Re: what fuel pump for my setup? (hybridvteceg)
what's the stock lph rating for an itr? because i was reading another post and someone said don't bother getting an upgraded fuel pump unless you plan on going fi.
Old Apr 9, 2003 | 02:57 AM
Type RS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BabyDaddy &raquo;</TD></TR><TR><TD CLASS="quote"> Check on a Walbro 195 lph in tank....</TD></TR></TABLE>
where can i find a walbro at? i did a search and came up w/ a lot of squat..
Old Apr 9, 2003 | 03:08 AM
turbodsmpower's Avatar
b18bturbo sells them on here check him out in the best buy forum
Old Apr 9, 2003 | 06:17 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type RS &raquo;</TD></TR><TR><TD CLASS="quote">what's the stock lph rating for an itr? because i was reading another post and someone said don't bother getting an upgraded fuel pump unless you plan on going fi. </TD></TR></TABLE>
I just said the itr is a 135 lph pump just like all the other DOHC VTEC. The SOHC and DOHC nonVTEC are 79lph. You should bother to upgrade. And also why bother with a 195 lph pump when you could get the 255lph for almost the same price and that way if you ever go boost or nitrous, you have it.
Old Apr 9, 2003 | 07:01 AM
turbochic's Avatar
Default Re: what fuel pump for my setup? (turbodsmpower)
check out https://honda-tech.com/zerothread?id=298292
really good prices and they are on special for H-T members
Psycho719
Oct 25, 2011 10:00 PM
attack666
Oct 19, 2010 11:47 AM
GoldLudeRay
Sep 19, 2010 09:50 AM
puertoricanboy90
10
Sep 13, 2008 10:56 AM
924doorEG
Sep 16, 2007 11:22 PM
