Check Engine Light
Old Apr 7, 2003 | 08:54 PM
ek9 ferio's Avatar
Default Check Engine Light
Can anyone tell me what does it mean if my civic DX is FLASHING a Check Engine Light? It's a 2000 civic DX w/ the EX Exhaust manifold. And yes i do have both the DX O2 sensors in the EX stock header. It was welded in by a muffler shop.
Any response is appreciated!
Old Apr 7, 2003 | 09:41 PM
97hb's Avatar
Default Re: Check Engine Light (ek9 ferio)
Might be misfiring. Short out the blue connector in the passenger side kick panel.
Old Apr 8, 2003 | 02:31 AM
EE_Chris's Avatar
If your just driving along and all of a sudden the CEL begins flashing at you, that is indicative of a misfire.
Can you pull some codes?
Old Apr 8, 2003 | 04:28 AM
sohc_boy's Avatar
are u running no cat? i saw no mention of it? an ex cat is a direct bolt on along with the manifold u already have. if u are running the 2nd o2 sensor without the cat that could be another reason for the cel.
Old Apr 8, 2003 | 08:22 PM
ek9 ferio's Avatar
If Misfiring is the problem, what can I do to fix it? I gotta mention it flashes ONLY when it's in idle and idle really shitty. Sometimes it go low as 300rpm and normally its suppose to idle atleast 800rpm.
fcardenas
Honda Civic (2001 - 2005)
Mar 16, 2018 12:56 PM
95 GSR B20VTEC
17
Nov 16, 2008 10:16 AM
BrianCivicDX
Oct 25, 2006 05:50 PM
nos4a2si
Feb 11, 2005 11:33 AM
Ludeboi
Aug 31, 2002 04:54 AM
