Check Engine Light
Check Engine Light
Can anyone tell me what does it mean if my civic DX is FLASHING a Check Engine Light? It's a 2000 civic DX w/ the EX Exhaust manifold. And yes i do have both the DX O2 sensors in the EX stock header. It was welded in by a muffler shop.
Any response is appreciated!
Re: Check Engine Light (ek9 ferio)
If your just driving along and all of a sudden the CEL begins flashing at you, that is indicative of a misfire.
Can you pull some codes?
are u running no cat? i saw no mention of it? an ex cat is a direct bolt on along with the manifold u already have. if u are running the 2nd o2 sensor without the cat that could be another reason for the cel.
If Misfiring is the problem, what can I do to fix it? I gotta mention it flashes ONLY when it's in idle and idle really shitty. Sometimes it go low as 300rpm and normally its suppose to idle atleast 800rpm.
95 GSR B20VTEC
17
11-16-2008 10:16 AM
nos4a2si
02-11-2005 11:33 AM
