** LOW Oil pressure on a b18b .... Running 3PSi ! ! ! ! **
Hi all, just found something weird today, the oil pressure on my b18b is really low, so low that some time it even trigger the check engine oil light. The pressure is usually 55psi at wot and 30 psi at idle (minus or less), now, it can barely reach 20psi at wot and it's mere 3 psi at idle. The engine is a 1999 and oil level it top.
Thanks
Thanks
