Disconnected IACV
Old Apr 7, 2003 | 08:27 PM
EF8_SiR's Avatar
Default Disconnected IACV
B16A1 in a CRX
Anyways, I've been having mass idle surges so decided to play around with my car. After doing some tests, the problem was traced to the IACV. I disconnected the electrical plug and my idle is perfectly fine. The only problem is now I only have curb idling (my idle does not change with engine temp). Also there is sputtering till my car warms up then it's fine.
Aside from the annoying CEL, i don't notice a diff in the driving performance except that at times it gets a bit choppy when i'm in cruising throttle position (constant mph). Vtec still engages, no mroe idel surge, etc.
Can anyone tell me if I'm doing any damage to my car by disconnecting the IACV? Also if I was to replace one, what model of USDM car would I be looking at (right now off top of my head I'm thinking the B17A)
thx
Old Apr 7, 2003 | 09:42 PM
blacksheep's Avatar
Default Re: Disconnected IACV (EF8_SiR)
No.. I don't think the B17 IAC valve will fit a 1st gen B16A. Those use the wider bolt pattern IAC valve. I'm not sure what other engine uses that one.
Old Apr 8, 2003 | 05:03 AM
sleeper4dr's Avatar
my understanding from other members here is that the 89-91 Si D16a IACV is a direct replacement for the B16 part. hth
Old Apr 8, 2003 | 05:14 AM
blacksheep's Avatar
Default Re: Disconnected IACV (sleeper4dr)
I think that's right.
Old Apr 8, 2003 | 05:39 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
No damage at all to drive with it disconnected.
If you want to get rid of the CEL, just stick a piece of rubber sheet or even two layers of duct tape over the holes and then put the IACV valve back on.
You will have to adjust the idle withthe idle screw at the T/B but it works. I did that for a while before I bought a new one. BTW, the IACV from a CRXsi or HF will work on the JDM B16 manifold.
Old Apr 8, 2003 | 07:05 AM
EF8_SiR's Avatar
Kick ***..
Thx guys.
I'll just take the one from my old engine..thx
Old Apr 8, 2003 | 07:11 AM
USDM 4G VTEC's Avatar
for example
some people on civic gets confused and use the wrong plug on the IACV..
i fucked up and i was using the IACV with a plgu that i tought was the right one... on DPFI to MPFI conversions u get an extra plug thats exactly the same one as in the IACV.. i changed it and make sure was the right wires... wich i think are grn and the other one red... plugged it and my idle got fixed.... now when cold idles @ 1200 and goes low as it gets warm... before i always had it on 800... wich didnt hurt anythign at all....
crazykid9137
Aug 18, 2007 02:09 PM
jaydoghondacivic25
Jan 30, 2006 09:01 PM
b16crx88
Mar 19, 2005 11:14 AM
acidx
Jun 5, 2004 02:15 PM
s2k
Feb 25, 2003 06:50 PM
