Whats works best to get off rusted botls?
Old Apr 7, 2003 | 06:15 PM
acatak's Avatar
Default Whats works best to get off rusted botls?
I'm installing my srpings friday before I head up to the track at night. I heard some of the bolts in the rear are a bitch and my car is a 95 so I'm assuming I might have some probs. What is the best stuff to put on them to free them up? I have a propane torch if that helps
Old Apr 7, 2003 | 06:16 PM
WhitEdRift's Avatar
Default Re: Whats works best to get off rusted botls? (acatak)
You can put soem WD-40 on'em and let them soak for a few minutes. That should do the trick.
Old Apr 7, 2003 | 06:17 PM
furious94ls's Avatar
PB blaster works well. Let them soak really good. Be carefull not to break those LCA bots as you will be screwed. Good luck
Old Apr 7, 2003 | 06:27 PM
acatak's Avatar
Default Re: Whats works best to get off rusted botls? (furious94ls)
where do u get pb blaster?
Old Apr 7, 2003 | 06:34 PM
neo1z's Avatar
PB Blaster is where its at --- go to Napa if you have one nearby -- or Pep Boys.
Old Apr 7, 2003 | 06:44 PM
DK4200's Avatar
Default Re: Whats works best to get off rusted botls? (neo1z)
yeah, spray it with something and work on it for awhile... i have a 98 with 50K on it and the rear bolt was a b*tch. It took a while with the impact gun. Same thing with this other kid i know on his 93 integra.
Old Apr 7, 2003 | 07:14 PM
zigs's Avatar
Default Re: Whats works best to get off rusted botls? (DK4200)
Yeah lots of times those rear bolts sucks if you cant get them off with all the other suggestions before you turn the impact gun up and break it off which they will and that can be a pain just heat the bolts up and put the impact on it while its still hot works everytime .
Old Apr 7, 2003 | 07:16 PM
Thumbsup420
Guest
Posts: n/a
Default Re: Whats works best to get off rusted botls? (zigs)
what you have to do is take that propane torch and melt them out... if that doesnt work just hold it there till they get really really hot then use a tool to remove them because when it gets warm it compress'
Old Apr 7, 2003 | 07:24 PM
KoRE's Avatar
Default Re: Whats works best to get off rusted botls? (Thumbsup420)
PB BLASTER!!!
and heat it up a bit depending on the location
Old Apr 7, 2003 | 07:28 PM
bo0sted's Avatar
Default Re: Whats works best to get off rusted botls? (KoRE)
I just cracked my rear bolt on Sunday. Now i need to take it in somewhere to get it drilled out. My car is also a 2000, so good luck.
Old Apr 7, 2003 | 07:31 PM
KoRE's Avatar
Default Re: Whats works best to get off rusted botls? (MwGSR)
which rear bolt?
i have an extractor set you can borrow
Old Apr 7, 2003 | 07:33 PM
bo0sted's Avatar
the rear bolt that holds the bottom of the shock.
Old Apr 7, 2003 | 07:46 PM
bo0sted's Avatar
kore instant message me on aol if you have it. (MwTwista is my name) I cant pm you yet cause i havent been here long enough.
Old Apr 8, 2003 | 03:05 PM
acatak's Avatar
what is the size of that rear bolt so I can go pick a few up just in case?.
Old Apr 8, 2003 | 05:56 PM
acatak's Avatar
ttt
Old Apr 8, 2003 | 06:40 PM
B2FiNiTY's Avatar
Liquid wrench is my best friend
zerovandez
Apr 7, 2014 07:34 AM
doomile
Suspension & Brakes
12
May 16, 2013 07:30 PM
dohctor_B
30
May 13, 2007 12:40 AM
ekdriven
Mar 18, 2005 10:39 AM
Integra_Nguyen
Aug 10, 2002 06:58 PM
