valvespring question
Old Apr 7, 2003 | 11:34 AM
servion's Avatar
Default valvespring question
Is a OBDII JDM b18c supposed to have dual valve springs on either intake or exhaust side stock?
When I changed my valve seals, my head only had outer valve springs on both sides...
Sorry... the archive search is still disabled
Old Apr 7, 2003 | 11:41 AM
kyle h.'s Avatar
Default Re: valvespring question (servion)
why would it have dual springs?
Old Apr 7, 2003 | 11:49 AM
1bad-eg's Avatar
I thought that b18c's had dual valve springs on the intake side. Sounds like that motor has been apart before you got it.
Old Apr 7, 2003 | 11:52 AM
servion's Avatar
Default Re: valvespring question (1bad-eg)
I had a machine shop do a test to make sure everything seated alright... so there is supposed be an inner spring on the intake side?
Could it be a difference between the JDM b18c and the USDM b18c? Or am I missing some springs?
[Modified by servion, 1:54 PM 4/7/2003]
Old Apr 7, 2003 | 05:12 PM
Doogie Howser's Avatar
gsr motors have dual intake springs the same as the itr springs, so you can switch your intake springs to the exhaust side and buy itr intake springs and have the same setup as an itr
Old Apr 7, 2003 | 05:43 PM
servion's Avatar
Default Re: valvespring question (Doogie Howser)
Is this true (dual intake) for JDM b18c's as well?
Old Apr 7, 2003 | 06:54 PM
NiiS's Avatar
I thought it was on the exhaust side, but I know for a fact one side (stock) had duals...
Old Apr 7, 2003 | 09:02 PM
b19coupe's Avatar
Default Re: valvespring question (sinister)
I can't speak for JDM B18C's, but USDM B18C1's have dual intake springs and single exhaust springs.
Old Apr 7, 2003 | 11:27 PM
servion's Avatar
Default Re: valvespring question (b19coupe)
Anyone know about the JDM b18c? CAn anyone confirm that they have dual springs on the intake side?
Old Apr 8, 2003 | 12:14 AM
leadfoot78's Avatar
When I got my JDM B18c (GSR) from Hmotorsonline it had dual on the intake side and single on the exhaust. I replaced it with better ones so I know for sure it should have dual on the intake side. If you look on the lift and duration of any cam stock or jun3 the inteake cam is more demanding than the exhaust.
stevann
Aug 20, 2013 08:10 AM
92db2gs-r
Feb 27, 2011 03:54 PM
chu77
Aug 13, 2006 06:11 PM
Convoy
Dec 29, 2003 09:48 PM
McFly
Feb 12, 2003 08:27 PM
