I'm in need of a new ECU...what should i get?
::cobes:: left a message earlier
I have a '95 Del Sol DOHC
this summer a new ACT clutch, and AEM cam gears will be installed cause i need a new timing belt and so i thought i might as well...
My ECU fried... shop said it was a hardware problem, and also said it needed to be replaced.
OEM is $1800
I was thinking of the AEM EMS, which is programmable with a laptop (got one), but ::cobes:: said go for mugen <http://www.kingmotorsports.com/produ...icle=Civic>. Mugen is not programmable and I think will lead to further problems unless I reinforce the valve springs, and change a lot more than just my cam gears, especially because of the increase in redline limit.
I'm looking for options...repair possibilites or replacements.
OEM is $1800
stock P30 ECU or Spoon programmed P30, either way very cheap and more then enough for your setup.
cheaper route is to go with a P28/P91 or JDM P08 thats chipped. (check my sig) 1/10 of the cost of replecment and more power then you need. (custom vtec/rev limit and so on).
I am also in Canada
I am also in Canada
Ill
Jul 20, 2004 05:36 PM
2000fbp
Feb 13, 2004 11:20 PM
