Needles dont move..
Old Apr 7, 2003 | 08:57 AM
white95's Avatar
Default Needles dont move..
Installed guage faces on my friends 95 GSR. Anyways, the needles dont work anymore. Is there some kind of blown fuse or relay or is there some kind of anti-tamper thing on the odometer that we tripped? HELP please, we dont know how much gas he has left, lol......
Old Apr 7, 2003 | 09:02 AM
Dan GSR's Avatar
Default Re: Needles dont move.. (white95)
did u pull off the needles to install the faces ??
if so , you probably killed the gauge....won't work anymore
best way to install faces is pulling the face around the needle...
Old Apr 7, 2003 | 09:16 AM
StyleTEG's Avatar
Default Re: Needles dont move.. (Dan GSR)
The gauge faces have to be very snug against the original ones, especially at the opening where the needles fit through.
My guess is there is some slight interfearance with the new faces and the needles, preventing them from moving. Try using some superglue and make sure all of the face is extremely flush.
Old Apr 7, 2003 | 09:34 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Needles dont move.. (StyleTEG)
Agreed, make sure the faces are completely flat. And part that touches the needles will keep them from moving. They are very sensative.
Old Apr 7, 2003 | 09:36 AM
white95's Avatar
We didnt pull the needles off, we slipped them over the needle. We did use superglue, none of it got on the needle bezel, and the faces are flush with the old needles. We'll get up under there again and see, though. Thanks.
[Modified by white95, 10:37 AM 4/7/2003]
Old Apr 7, 2003 | 10:17 AM
ChopstiX's Avatar
start off by making sure your gauges arent rubbing your needles.. then go to the back of the gauge cluster and make sure all connections on correct in securely in. other then that I dont know what the problem would be?
WT-EF
Sep 18, 2009 08:50 AM
nocturnaldragon
23
May 3, 2004 03:01 PM
domepizzle
Dec 21, 2002 08:54 AM
SIMATIC
Oct 22, 2002 08:21 AM
