my cars going CRAZYYYYYY!!!!!!!!!!
Old Apr 7, 2003 | 08:42 AM
pr0jektdc2's Avatar
Default my cars going CRAZYYYYYY!!!!!!!!!!
okae ive been havign a problem with my car...the starter has been pretty weak...i found out that my starter terminal was loose so i began to tighten it...as i was doing so i tapped something and it SPARKED!...[i know stoopid me for not unplugging the terminal...]now when i tried to start my car nothing happend...i fergot to plug my spark plug wires back in...now when i attach the battery cable...it tries to start up and smoke comes from my battery terminal...it melts into it! why is my car trying to start when theres no KEY!!!!!!!!!!!!!! please someone help...im going nuts!!!!!!!!!
Old Apr 7, 2003 | 08:48 AM
pr0jektdc2's Avatar
Default Re: my cars going CRAZYYYYYY!!!!!!!!!! (pr0jektdc2)
sorry about the double post...BUMP!!!!!
Old Apr 7, 2003 | 08:54 AM
GSRMatt's Avatar
25 Year Member
You may have screwed up the starter relay, freezing it in the "on" position.
Old Apr 7, 2003 | 08:55 AM
pr0jektdc2's Avatar
Default Re: my cars going CRAZYYYYYY!!!!!!!!!! (GSRMatt)
how would i fix that!?!?
Spade's Avatar
You have a short in the terminal wire, make sure it's not frayed and touching the chasis.
Old Apr 7, 2003 | 08:58 AM
pr0jektdc2's Avatar
Default Re: my cars going CRAZYYYYYY!!!!!!!!!! (Spade)
hi where would the terminal wire be!?!?
Old Apr 7, 2003 | 09:11 AM
Spade's Avatar
Around the connector. Also inspect for damage to the battery.
fralick
Sep 3, 2011 10:51 PM
luv2boost
Oct 25, 2008 06:47 PM
Rat_Bear
Feb 7, 2008 07:09 AM
GoodEyeSniper
17
Sep 8, 2006 11:31 PM
EF9 JAMS!!!
Sep 23, 2004 10:21 AM
