Cost of b16 swap
Sometimes searching will help.
https://honda-tech.com/zerothread?id=463391
And if your talking about just parts, well what parts did you want to know about. Make a list and I can tell you how much everything is gonna cost ya. But seem people buy more parts then others, so its hard to say.
http://www.jdmcars.com
This guy told me like $2500 for everything installed or something like that. I can't remember exactly. But I thought it was a good price!
That's a low figure, but I replaced and upgraded a lot of stuff. With new exhaust, racing clutch and pressure plate, new gaskets, belts, I think I'm around $2500. I would highly recommend doing the clutch, the one that came on mine was toast. You could probably get away with getting a OEM clutch and be all done for around $1700.
"After a thorough inspection, I came to te conclusion that all the upper seals were fine, so all in all motor, plus parts i spent just under 1500. "
howd u get away doing it so cheap? the engine alone runs for $1100 + shipping, then mounts, and some other misc stuff should be replaced - timing belt and water pump are almost a must while the engine is out
[Modified by SteveeeO, 3:26 PM 4/8/2003]
Practical Breakdown(Low prices, expect to pay more):
Engine + Shipping $1350
Mounts HCP $275
Water Pump $50
Timing Belt $50
Fluids $30
Filter + Misc $50
OPTIONAL OEM clutch $200
Price W/O a new clutch $1805
Price W/ new OEM clutch $2005
Mounts HCP $275
Water Pump $50
Timing Belt $50
Fluids $30
Filter + Misc $50
B16a XSi swap including shiping $1550
ha sport mounts(price with engine) $350
new timing belt, water pump, fluids, shift linkage modifacation, a few wires and supplies, radiator hoses, pedals for manual conversion, 2nd gen integra throttle and clutch cables, axel, lengthen exhaust pipe, bolts, bitch pin, drinks... ~$400
total= $2300
Note: The engine I recived from HMO was very clean and only needed a few parts to go in which helped keep the cost down. I did not replace the clutch, because when I took it out to replace it looked/measured within new specs, and has been fine with no slips for 5k miles so far. Stock motor with stock exhaust dynoed at 142 hp and 101ft/lb(lol). Now time to build the head...
total= $2300
b16a swap 1150? password jdm
hcp mount copies 250
fluids, radiator hoses, clutch disk etc 100
price breakdown at my site http://www.geocities.com/droppedcrxsi/B16a.htm
Ryan
Ryan
Actually, one thing I totally overlooked was the fact that my brother bought me my mounts cause he w totally stoked that his little bro was finally bustin his swap. They're Todems ( canadian made, life-time warranty, no complaints) ran about 250. A new Exedy Clutch disk is only about 80 bucks. So all in all about 1700 realistically. As far as reliability stands, I don't burn an ouce of oil, or have thrown any codes form the get go. I'm running stock airbox and 91 si exhaust ( 1-3/4' i think), I don't have one aftermarket part besides minor suspension. I wanted to be able to appreciate all the mods I do from the ground up and I pulled nuts on 95 mustang 4.6 the other night so I think i'm off to a good start.
oh yeah, if at all possible try to pick up your motor yourself, that's a lot of money you'll save that can go to other important things you'll need. like
Thanks for all the replies, I have about 2200 saved up and will probably be pickin up the motor myself, so im figurin i got about enough to do the swap. I was gonna go zc but they are kinda hard to get ahold of.
liyan1430
May 24, 2011 08:57 PM
vitrox
Nov 22, 2004 08:10 PM
chinaski
Feb 8, 2003 11:19 PM
