noisy clutch ?
Old Apr 6, 2003 | 08:37 PM
dwn-shift's Avatar
Default noisy clutch ?
I got a stage 3 clutchmasters clutch in my lude, and when the pedal is not pushed down the clutch chatters like no tommorow. I figure its just the throw out bearing, but i pulled the trans and noticed that the springs are kinda loose. Is it normal for the springs to be kinda loose, the clutch maybe only has 1k miles on it. I also have a fidaza flywheel if that helps any to explain the problem.
Old Apr 7, 2003 | 07:44 AM
allmotorEG-SI's Avatar
Default Re: noisy clutch ? (dwn-shift)
I have a stage 3 on my b18 engine in my civic. It makes a whinning noise every time I engage the clutch. Is that a throwout bearing?
Old Apr 7, 2003 | 10:06 AM
TGUNNER's Avatar
Default Re: noisy clutch ? (gixxerdemon)
I have a stage 3 also and it makes that weird noise also when engaging 1st gear..
Spo0NFed E M 1
Jun 15, 2006 03:30 PM
KArowd
Apr 2, 2006 05:39 PM
allmotorEG-SI
Apr 15, 2003 11:17 AM
echo999
Dec 17, 2002 01:57 PM
