Squeeling noise?
Old Mar 29, 2006 | 04:34 PM
KArowd's Avatar
Default Squeeling noise?
Hi there, problem is, when im at a stop light, and it turns green, i take off in first and as i do, i hear a screech coming from under the car, it also happens if i roll to a sign in second and take off. so happens only in low rpm's. Anyone guess what the problem could be? thanks alot.
p.s. i have a stage 3 act clutch, could this have to do with anything? thanks.
Old Mar 29, 2006 | 07:28 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Squeeling noise? (DOughh)
Dang I have the exact same prob on my 98 teg with 84K- all stock. It began at about 40K miles and has not gotten worse, so I have left it. It is definately connected to the tranny, as it occurs while I let the clutch out.
I think it is a throuout bearing or something like that...
Old Mar 29, 2006 | 07:33 PM
PLAGUED_DB7's Avatar
Default Re: Squeeling noise? (Rtzx9r)
Throw out bearing? Does the noise stop when you tap the clutch?? How about in the morning??
Old Mar 29, 2006 | 07:37 PM
sh!tsWEAK!'s Avatar
Default Re: Squeeling noise? (PLAGUED_DB7)
THis is so wierd! This exact same thing just started happening tonight to me and now I see this thread. I also have a ACT Stage 3 clutch and it happens only when I start in first gear and let off the clutch. Bump for an answer!
Old Mar 29, 2006 | 07:41 PM
Haleiwa-Brando's Avatar
Default Re: Squeeling noise? (TopSecretEg6)
Before it's a clutch issue, I'm going to take a stab in the dark that it's either your:
Power steering belt is loose
Alternator belt is loose
A/C belt is loose
Check to see if your belts look glazed on the tooth side or if there is an cracking. The belts should not have much deflection in them. If you have a Helms, that should tell you what the +/- tollerences are.
Old Mar 29, 2006 | 07:57 PM
tegra96's Avatar
check all the belts prob. the alternator belt.
had the same problem on my old 94 hatch civic
Old Mar 29, 2006 | 09:01 PM
KArowd's Avatar
I kinda thought it was the alternator belt, but wasnt sure. makes the noise anytime during the day, when i release the clutch slowly and start to accelerate, the squeeling comes on, Im gonna check the belt tomorow and see whats up. thanks guys!
Old Mar 31, 2006 | 08:24 PM
Rtzx9r's Avatar
GDD 1%
Default Re: (DOughh)
I think it is more tranny related than a belt- and here is why:
THis only happens a few times when the car is cold. It only has ever occured starting out in 1st or shifting to 2nd. On the last 1/2 of letting out the clutch, there is a sharp, fast, high pitched squeel. THe slower I let out the clutch,m the longer the squeel.
Could it really be belt related, as I am slowing down the engine RPM and the belts are "moving"?
Old Apr 2, 2006 | 05:39 PM
Rtzx9r's Avatar
GDD 1%
Default Re: (Rtzx9r)
Anyone know what this could be?
DeeJaaY209
14
Sep 15, 2013 10:40 PM
KlickityClack07
Honda Civic (2006 - 2015)
Feb 28, 2010 05:37 AM
Vadim_D
Jan 14, 2009 08:26 PM
phyzJunkieCivic
Jul 14, 2006 12:42 AM
Rubixcu7
17
May 8, 2006 08:50 AM
