need parts info on integra rear swaybar onto 4dr 92 civic
a friend of mine needs to know what parts will be needed in order for him to fit a gsr rear swaybar (14mm) onto his 92 civic 4 door. all he has is the bar. i'd like to know the part numbers for bolts/ endlinks/ brackets/bushings, etc.
i'd also like to know if we need to modify anything in order to make it fit right. thanks in advance
Contact BSQ for the kit, this is a post made by him in the integra forum
[Modified by 97RedTegGSR, 11:24 PM 4/6/2003]
1.) Go to http://www.acuraautomotiveparts.net/...searchpart.jsp and enter the following part numbers to order:
52300-ST7-Z01 rear swaybar
52315-ST7-Z01 swaybar bushing (2 needed)
52308-SS0-000 bushing bracket (2 needed)
52316-ST7-Z00 endlink bushing (2 needed)
52312-ST7-Z00 endlink bushing collar (4 needed) – this part can be reused from the stock swaybar
90175-ST7-Z00 bolt (8x35) (2 needed)
94050-08080 flange nut (8mm) (2 needed)
2.) Go to http://www.geocities.com/bretq/mounting_kit.html to order Type-R rear swaybar mounting/reinforcement kit (aka BSQ mounting kit).
3.) Go to http://www.geocities.com/bretq/swaybar_install.html for complete step-by-step instructions (with photos) for installing the Type-R rear swaybar.
_______
Bret - '94 GS-R
_______
Bret - '94 GS-R
yeah i've looked at that, but will the instructions work the same for installing a gsr 14mm swaybar onto a 92 civic? i don't want to order the pieces used on a type r rear swaybar and them not work correctly with the gsr swaybar.
will one of these work for the endlinks?
http://www.jegs.com/cgi-bin/ncommerc...86&prmenbr=361
if so, what size?
[Modified by TheRoxorcist, 4:48 AM 4/7/2003]
if so, what size?
Rhymenoceros
Sep 28, 2007 09:39 AM
dLo GSR-stolen-now-WRX
Dec 23, 2002 01:49 AM
DreamSpeed
Nov 2, 2001 11:30 AM
