will 94-2001 integra LCA fit on a 92 Civic CX?
i was wondering if the GSR rear sway bar will fit on a 1992 CX? will it bolt on directly or do i have to change to integra control arms? i believe its the same bar for both cars right? and anyone know how big the rear gsr bar is? thanks
Re: will 94-2001 integra LCA fit on a 92 Civic CX? (DreamSpeed)
you need the LCA's and endlinks and swaybar and D-brackets.
bolts right in, easy as pie.
rear GSR bar is 14mm I think.
~it is easy to upgrade to an ITR 22mm rear swaybar while doing this install,
A&H motorsport can get you the ITR swaybar and needed parts to upgrade from a GSR setup for only $100 or so.
HTH
HTH
Re: will 94-2001 integra LCA fit on a 92 Civic CX? (owen_the_soyboy)
HTH
HTH
DreamSpeed
11-04-2001 12:41 PM
