shaking when turning
Old Apr 6, 2003 | 05:20 PM
Rob!'s Avatar
Default shaking when turning
when i go around a turn to the right the passenger side shakes real bad. it comes from the front suspenion area. when i turn left or go straight it is fine. i replaced th drivers side axle before the wap but not passenger side. anyone know what is causing this. i think its my passenger side axle but im not 100% sure...if you have any suggestions let me know.
Rob
Old Apr 6, 2003 | 06:09 PM
Ef Whore's Avatar
Default Re: shaking when turning (RaceFacer)
I would think the axle would shake no matter which way you turned if it was bad. Shaking can be many things as you know.(rack, joints, etc.) Jack it up and run through the susp. looking for play or looseness. If it's all good then buy a remanufactured axle and throw it in, see whats happens. They are only about 80 beans anyway.
Old Apr 7, 2003 | 04:48 AM
Rob!'s Avatar
Default Re: shaking when turning (Ef *****)
i went over all the suspension and made sure everything is tightened and still no luck. i think im going to buy a new axle today. still taking suggestions though. TTT
Old Apr 7, 2003 | 07:27 AM
Mr Furball's Avatar
what about a lost wheel weight?????
Old Apr 7, 2003 | 09:28 AM
Rob!'s Avatar
Default Re: shaking when turning (FURBALL B-16)
both of my tie rods dont look so great either.
Old Apr 7, 2003 | 11:30 AM
CRexcellence's Avatar
New User
Hey RaceFacer,
I am having the same problem. When I go around a left turn at about 20 or more I get this vibration/noise from the right axle. I just put in my ls/vtec and got the driveshaftshop stage 1 axles for it. I am going to inspect my car tonight at work. Let me know if you find anything
Old Apr 7, 2003 | 11:45 AM
sbigblack02's Avatar
Default Re: shaking when turning (jrx2002)
my friend has the same problem now and it is his steering rack $257 dollars at pepboys look in on that
Old Apr 8, 2003 | 05:59 PM
Rob!'s Avatar
Default Re: shaking when turning (sbigblack02)
damn i hope its just my axle
Old Apr 9, 2003 | 12:44 AM
SiR Kid's Avatar
New User
Default Re: shaking when turning (b16hf)
I have the same problem on the right side of my car when I turn left... makes a nice scrubbing/vibrating noise... It's pretty bad, actually. Sounds like the tire's about to pull the fender under the car, but nothing's scrubbing!
Old Apr 9, 2003 | 06:30 AM
Rob!'s Avatar
Default Re: shaking when turning (SiR Kid)
snow wont go away so i cant really look at it yet...anyone else??? no solutions???
Old Apr 9, 2003 | 07:43 AM
ricodemus's Avatar
My dss stage 2 does that on the drivers side. It sucks because it depends on my ride height. I put the perch up a little on the koni's and it went away except for hard lefts and big bumps. If I have a passenger, it becomes much more sensitive and many left turns suck. It feels like the axle is going to rip in half. When I pull the car apart this spring, I'm gonna check on it more and talk to the dss.
Old Apr 15, 2003 | 01:12 PM
Rob!'s Avatar
Default Re: shaking when turning (ricodemus)
ok update....i put the new axle on and the car still shakes real bad when i turn right....what are the other possibilities? i cant drive my car it is so bad and i need it fixed asap. someone pleaseeee help me!!!
Rob
Old Apr 15, 2003 | 05:20 PM
Rob!'s Avatar
tTt
Old Apr 15, 2003 | 05:41 PM
SiR Kid's Avatar
New User
Kinda makes me wonder if the steering rack and bushings for it really could cause this...
My car had a pop to it when I would turn the wheel sometimes, but this noise just started happening out of nowhere...
Before spending $250+ on a rack, I'm going to throw new axles, and a new midshaft at it, and see if that hels at all. It really helps knowing the guy at the parts counter of the Honda AND Acura in town .
Old Apr 15, 2003 | 07:24 PM
Ef Whore's Avatar
Dont buy a rack....this is something swap related....b16 ef peeps help this guy out. You all know u hate it when your car shakes. I do.
Old Apr 16, 2003 | 07:15 PM
Rob!'s Avatar
i swapped out my hub assembly for crx si rotor hubs and caliper and all that crap. i got it from a junk yard. could this be bad? i did not have this problem before swap
Old Apr 16, 2003 | 07:35 PM
tilt's Avatar
maybe the wheel bearing has play? jack the car up and try moving the wheel back and forth - grab the wheel vertically on top and bottom and shake it. shouldnt move at all.
Old Apr 17, 2003 | 12:05 AM
91bizzerhatch's Avatar
did you by 86-89 integra axles,because i had that problem and i needed that.
Old Apr 17, 2003 | 07:22 AM
Rob!'s Avatar
Default Re: shaking when turning (91bizzerhatch)
i bought 90-91 integra axles...and i did shake the wheel....do i have to turn it in the right position where it shakes then move it back and forth
Old Apr 17, 2003 | 09:21 AM
APEX CRX's Avatar
You should check your lower ball joint, all the other things you checked are parts that would vibrate even when going straight. the ball joint would move around when turning because the susp angle changes when turning
dohc_profile
May 30, 2008 09:09 AM
...Baker
19
Aug 14, 2006 09:59 AM
Cuong-nutz
16
Apr 17, 2005 08:50 AM
technine
11
Dec 20, 2002 08:42 PM
