I might get Nitrous tonight... but first i have some questions...
Old Apr 6, 2003 | 02:56 PM
DK4200's Avatar
Default I might get Nitrous tonight... but first i have some questions...
What Kit should i get... NOS, ZEX, Edelrock, Venom... i have heard that ZEX is the best. Also does the kits come with different nozzles or just one? Do i need bigger fuel injectors? I did a search but with little help. Go to my webpage in my signature to see my mods if that helps you to determine what kit i should get. I will hit 13's this year damn it!!!
Old Apr 6, 2003 | 03:02 PM
envious1320's Avatar
Default Re: I might get Nitrous tonight... but first i have some questions... (DK4200)
Well i have the zex kit well had it anyway i really liked it i got more then one set of jets sizes. I liked it a lot but decided that i want to go all motor so mines gone. I was able to pull some mid to high 13's with it set at the 75 shot.
Old Apr 6, 2003 | 03:04 PM
DK4200's Avatar
Default Re: I might get Nitrous tonight... but first i have some questions... (envious1320)
cool, so you think a 75 shot would be ok with stock internals? I have I/H/E, UR Pullies, B&M FPR w/ gauge. I have a 98 LS with B18B. let me know
Old Apr 6, 2003 | 03:07 PM
DK4200's Avatar
Also should i go wet or dry???? and what spark plugs should i get??? i have NGK Platinums now with only about 7,000 miles on them
Old Apr 6, 2003 | 03:18 PM
neo1z's Avatar
You want to get 2 step colder plugs, non platinum for sure.
You will probably want to retard the timing 2 degrees or so. Also, I would get a dry kit if you only plan on shooting up to 75 - if you want to go higher, id suggest a wet kit. The ZEX kit is cake to install, and I would recommend this if you are going dry...if you are going wet, id probably just go ahead and get a NOS kit.
Also, I personally would not shoot above 60 on a b18b unless I got into some better fuel and ignition stuff - just me. I love my car.
You can run 50 all day on the plugs and retarded timing.
Old Apr 6, 2003 | 03:33 PM
DK4200's Avatar
Default Re: I might get Nitrous tonight... but first i have some questions... (neo1z)
what are the 2 step colder plugs? are they made by NGK? what about denso iridiums?
Old Apr 6, 2003 | 03:54 PM
sickda6's Avatar
get NITROUS EXPRESS!! youll be glad....my 90ls went 13.5@101 with i/h/e, 50 shot, 24.5in slicks. they dont even make a dry kit because wet is the ****. btw ive squeezed on many setups and have alot of experience with nx, zex and nos. the plugs are bkr7e. also no timing retard is required for nx.
[Modified by sickda6, 12:54 AM 4/7/2003]
Old Apr 6, 2003 | 03:59 PM
neo1z's Avatar
Default Re: I might get Nitrous tonight... but first i have some questions... (sickda6)
Those are indeed the plugs to get --- NGKbkr7e...however...I realize timing retard is not REQUIRED by any nitrous kits --- but it definitely is recommended...and I think Id go ahead and retard it.
Old Apr 6, 2003 | 04:24 PM
DK4200's Avatar
Where can i get Nitrous Express and how much does it cost? Also where can i get those plugs?
[Modified by DK4200, 1:36 AM 4/7/2003]
RZA24
Jan 2, 2007 02:40 PM
.Grimace
Feb 7, 2006 07:12 AM
gsrtxjarrod
Jan 8, 2005 09:33 PM
hondaeg8
Dec 12, 2004 08:14 PM
f22suzuka
Jul 27, 2003 09:59 AM
