Civic type R manifold install
Old Apr 6, 2003 | 02:17 PM
DC2 12's Avatar
Default Civic type R manifold install
JUST INSTALL civic TYpe R(PCT) manifold on my b16a , now i gotta a problem, it starts fine, idles at 1.5 rpm, bu t when i step on the gas it bogs out, when i step on my gas pedal all the way down it stalls out on me . Any solutions ? also the the heater hose from the fast idle thermostat valve doesnot have a slot to be plug into the intakemanifold?
_______
Old Apr 6, 2003 | 06:47 PM
DC2 12's Avatar
Default Re: Civic type R manifold install (hoacun)
anyone help
DC2 12's Avatar
can anyone help
Old Apr 7, 2003 | 01:19 AM
1 speedstar's Avatar
make sure you didn't mix up the MAP and the TPS sensors. that sounds like a problem i had -- bog then die out. try switching plugs and see what happens, HTH
Old Apr 7, 2003 | 10:29 AM
Katman's Avatar
Default Re: Civic type R manifold install (1 speedstar)
yes, and if you did mix up the MAP & TPS you should be getting a check engine light for either sensor.
as for the coolant lines and FIV, you can just block those off or reroute them to each other so they recirculate. it won't sacrifice/affect performance at all.
mitsuman
Jan 21, 2008 07:26 PM
mutantmopar
Aug 2, 2007 03:06 PM
ritalin
Jun 3, 2004 07:10 PM
simplypinoyy
May 14, 2004 01:36 PM
