distributor question
From: chillin in that city called queen creek, but homes the atl
ok my distributor is throwing a code 8 check engine light. and a code 8 stands for tdc sensor now my question is can u just change the tdc sensor out of the dist. and if so witch sensor is it and is this possible and to this is for a 95 obd1 gsr dist. and the reason i am asking is that i have a 01 obd2 gsr dist. lying around and wouldn't mind just switching the parts around
I remember somebody saying the individual sensors aren't available, but I don't know that for sure. I suppose TDC is the one with 2 points on the distributor shaft.
distributors cost 200 250 fort a 94-95 gsr i just want to see before i have to buy another can i fix the one i got because i have an 01 gsr distributor lying around and i wanted to see if i could just switch that sensor and were in the distributor is this sensor
wht/blu and the org/blu wires go to the tdc sensor so trace it and find it. id just try it if it doesnt work just put the part back in the otherone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetdreams02 »</TD></TR><TR><TD CLASS="quote">distributors cost 200 250 fort a 94-95 gsr </TD></TR></TABLE>
I'm just wondering where you can find one for that cheap?
If you have an exra GSR distributor just use that one. I believe they have the same number of wires. 9 total. All you have to do is change the connector by taking out the pins. obd1 uses 2 connectors. One with 2 wires and the other with 7. ob2 just has 9 all in one connector. I'm about to put a 2000 si dist. In my obd1 teg for ls/vtec. Hope this helps.
