Fiber images hood won't fit proper.
Old Apr 5, 2003 | 03:20 PM
roydogg's Avatar
Default Fiber images hood won't fit proper.
It kinda pops up alot on the driverside buy the headlites any way to fix this problem?
Old Apr 5, 2003 | 05:48 PM
CunninLynguist's Avatar
Default Re: Fiber images hood won't fit proper. (roydogg)
There are little rubber tabs that hold the hood up. They are right about the light..
Turn them right so they go in the frame alittle more. You can adjust the hight like that.
Old Apr 5, 2003 | 08:06 PM
roydogg's Avatar
Driver side
Its only the driver side that is lop sided, passenger side is nice and tite.
It's not hittin anything here
The passenger side is fine its just has a like 1" gap on the driver side. So I put a rim on top of it to see if it'll bend back. Any help would gladly be appreciated
Thanks,
Roy
Old Apr 5, 2003 | 08:24 PM
slvrcivic97's Avatar
Yeah, just turn the drivers side rubber **** to lower it some until you get the height right.
Old Apr 5, 2003 | 08:36 PM
roydogg's Avatar
Default Re: Fiber images hood won't fit proper. (slvrcivic97)
I'm sorry but what rubber ****? The hood isn't hittin anything. I think I might need hood pins. Can carbon fiber bend if I left a rim on top of it for a while as weight to hold it down?
Old Apr 5, 2003 | 08:37 PM
buddha429's Avatar
r u sure its not hitting that rubber piece.... just turn it a little lower and see if that helps... l8rz
Old Apr 5, 2003 | 08:55 PM
The rubber ***** on the left and right side that help adjust the hood position. But if the hood isn't touching anything then.....??I would call back the people who you got the hood from and ask for an exchange. It should fit right.
Old Apr 5, 2003 | 08:59 PM
roydogg's Avatar
Default Re: Fiber images hood won't fit proper. (buddha429)
Its like 1" from that rubber thing. But when I push down on the hood it makes the whole hood even on both sides. Do you think hood pins will fix the problem?
Old Apr 5, 2003 | 11:21 PM
(__________)'s Avatar
Does your car have a clean title?
Old Apr 6, 2003 | 03:12 AM
Mr.SpiLLz's Avatar
Default Re: Fiber images hood won't fit proper. (steves98itr247)
I really know nothing but is there supposed to be that gap between your fender and front bumber/headlights?
Old Apr 6, 2003 | 04:01 AM
mugen76's Avatar
Default Re: Fiber images hood won't fit proper. (MrSpiLLz)
the "gap" that you're referring to is not supposed to be THAT bad.
hood pins at the corners will solve it. this does make me wonder if the car was previously in an accident tho. i'm sure you don't wanna here that. did you make sure the hood is mounted correctly on the left side hinge?
Old Apr 6, 2003 | 04:16 AM
PoW3l2BaN's Avatar
my fiber images hood is a lil higher on the driver's side too..but it doesnt pop up like that in the front. They told me to leave the car out in the sun and put some weight on it and it will 'mold' into place. i havent done this yet, but whenever i drive the car, the hood fits better cause the engine heat allows it to flex. I hope you know what i mean.
thirsk66
Dec 5, 2014 11:34 AM
hondatuner20
Jan 1, 2006 09:00 PM
ekhatchgirl
Aug 23, 2005 11:29 PM
Benbuilt4u
47
Oct 20, 2003 03:36 PM
93civicb16a
May 2, 2002 08:17 PM
