Advancing timing...search still disabled!!!
Old Apr 5, 2003 | 10:43 AM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
Default Advancing timing...search still disabled!!!
Well im trying to figure out the EXACT way you are supposed to advance your timing(ignition). Ive read SOOOOO many different ways to do this but i dont know which way to do it. Some say that you have to start your car and advance it until you hear it knock...then turn it back a few degrees...then reset your ecu. Does that seem right to you? Also which way do you turn the dizzy to advance it...i think its to the firewall but im not sure? I know that this has been covered a BILLION times but the search is still disabled I hope that we get a better search engine after ll of this waiting...cuz the old one just sucks ***. Thanks
Sean
Old Apr 5, 2003 | 10:55 AM
altoid's Avatar
Default Re: Advancing timing...search still disabled!!! (sCeRaXn)
i dunno how to do it really, but how are you gunna move a cam gear moving at 350-750 rpms?
Old Apr 5, 2003 | 11:13 AM
elpermgrande's Avatar
Default Re: Advancing timing...search still disabled!!! (altoid)
he is talking about timing by the dizzy.advancing is towards the firewall.
Old Apr 5, 2003 | 03:45 PM
ThatRicerDaniel's Avatar
when you advance and retard your timing you can hear the motor.. when the motor sounds like it speeds up then your advancing .. when you hear it slow down your retarding . its a real faint sound so you have to listen carefully. good luck
Old Apr 5, 2003 | 04:42 PM
the DR.'s Avatar
Default Re: Advancing timing...search still disabled!!! (NitrousDreamz)
get a timing gun.. loosen the bolts, put a jumper wire in the connector located behind the passengers kick panel, set the timing to whatever you want and tighten the bolts
looking directly at the distributor, counterclockwise is to advance
riccyda27
Mar 16, 2009 10:53 AM
darkd1gt
Nov 21, 2005 08:45 PM
MenaceL.A.671
Sep 10, 2005 04:09 AM
mongoliandonuts
Aug 21, 2004 04:54 PM
EGcivicBoy
Nov 12, 2003 11:08 AM
