pinging noise while driving...
Old Sep 7, 2005 | 11:32 PM
MenaceL.A.671's Avatar
Default pinging noise while driving...
eversince i advance my intake cam gear to +3 and advance my dizzy... my car has been pinging..?? do yall know what would be the problem...? im thinking my timing might be off??? thanks.
Old Sep 7, 2005 | 11:54 PM
Default Re: pinging noise while driving... (m2slsvtec)
bump!
Old Sep 8, 2005 | 05:53 AM
robbieshonda's Avatar
timing might be alil off could be detonation wouldnt be able to tell without hearing it
Old Sep 8, 2005 | 06:44 AM
t3to4e's Avatar
Default Re: pinging noise while driving... (robbieshonda)
i second that
Old Sep 8, 2005 | 07:06 AM
Used2beAb16's Avatar
U do know that if you advance the intake cam 3 degrees that u also advanced the ignition timing 3 degrees at the same time right??? (they are connected u know)
So.. if u already jacked the timing 3 degrees from teh cam, then went and bumped the dizzy you are running alot of timing, U need to retard the dizzy a degree everytime u advance the cam a degree in order to maintain 16 degrees of timing.
Old Sep 8, 2005 | 07:07 AM
Default Re: pinging noise while driving... (Used2beAb16)
and i forgot to mention, you are most likely detonating with all that timing and thats why u need to pull some of that back.
Old Sep 10, 2005 | 12:56 AM
yup.. it was my bad without using a gun... but **** its slightly pinging right now... is there any other way to take that pinging noise out...?
Old Sep 10, 2005 | 04:09 AM
retard the timing on either the cam gears or the distributor! ITs that easy!
Treyschls
Apr 13, 2023 07:04 AM
johnwohl
Apr 1, 2008 07:29 PM
TranspeedMotorsports
Nov 12, 2006 09:11 AM
1.8Tities
Sep 8, 2002 03:32 AM
