How to get rid of Haze on headlights?
Well my headlights on my 96 civic or all hazy and ive tried using plastic polish, rubbing compound and 1000 grit wet sanding paper and it help but there still hazy. Is there anything I can use to clean them up a bit more? thanks
most likely its on the inside..i had the same problem and i used a blowdrier and some plastic cleaner..its evaporated most of the haze off..but u have to seal the lights up right or else you'll get moisture in there
http://faq.auto.light.tripod.com/hl-front-lenses.htm - everything you need to know about repairing/maintaining your lenses.
[QUOTE]Toothpaste.. wet the lights a bit.. and rub in some toothpaste generously..
let it sit about 5 mins.. get a clean somewhat damp towel.. and rub out the paste.. then dry.. should be somewhat clearer.. it worked on my eclipse when i had it. and a few other cars...
[QUOTE]
also works well on scatched CD's.
[QUOTE]
automobile, eadlight, haze, hazed, headlamps, headlight, headlights, inside, plastic, rid, toothpaste, tricks
