fogged headlights
Old Feb 6, 2005 | 03:53 PM
KanzenR95GSR's Avatar
Default fogged headlights
anyone have any tips on how to clear my fogged headlights up without actually having to replace them?
Old Feb 6, 2005 | 04:18 PM
KeithsDAteg's Avatar
Hair dryer and a **** load of silcone.
Old Feb 6, 2005 | 04:48 PM
Acura_I-RS's Avatar
Default Re: (KeithsDAteg)
had the same problem, took both my heaqdlights out, stuck them in the oven at 300 degrees for a little bit, 15 mins or so, then that loosens the glue in them, pull them apart, clean them up very good, and seal the **** out of them so they dont leak, min was cracked, so i had a lot of crap built up in there, but it saved me from buying new headlights..
Old Feb 6, 2005 | 05:56 PM
mr.beeks's Avatar
Default Re: (Acura_I-RS)
http://members.tripod.com/brok...e.htm
use some toothpaste to polish the outside they will look like new
Old Feb 6, 2005 | 07:58 PM
yangrou8's Avatar
Default Re: (mr.beeks)
havent tried this but heard it works well:
http://www.team-integra.net/se...D=662
it's a product called nevrdull by eagle one.
Old Feb 6, 2005 | 10:17 PM
Dee A Nine's Avatar
Default Re: (yangrou8)
you guys make it seem more complicated than it already is...
homie just leave your lights on... the small amounts of heat from the bulb should cause those stupid water deposits to disappear... it worked on mine.
Old Feb 6, 2005 | 10:21 PM
BlackThorN's Avatar
for how long
if you leave em on for every either your battery dies or you need to go fill up a new tank of gas
much easier to SOLVE the problem and reseal em
or replace em
Old Feb 6, 2005 | 10:23 PM
timmy8151's Avatar
Default Re: (Dee A Nine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dee A Nine &raquo;</TD></TR><TR><TD CLASS="quote">you guys make it seem more complicated than it already is...
homie just leave your lights on... the small amounts of heat from the bulb should cause those stupid water deposits to disappear... it worked on mine. </TD></TR></TABLE>
The problem is that this is just a temporary fix. The condensation is going to come back. Resealing the lense is the best option is there's a condensation problem.
To the original poster, are you lenses just dull or is there a condensation problem?? If they're just dull, then using EO Never Dull will clear up the lenses. However, if you have a leak, then resealing is the best option.
Old Feb 8, 2005 | 04:19 PM
go250mph's Avatar
3M makes a light cut rubbing compound for repairing flaws in paint.Works on headlights too.Just takes 4 to 5 times going over them.Don't just put it on like a wax either.rub that stuff in.If it tries to dry while your rubbing,put it on there thicker.Got the stuff at WAL-MART.
thomst4R
Oct 15, 2005 01:53 PM
bertyman
Honda S2000
Oct 12, 2005 04:38 PM
SIcivicHATCH
Jan 13, 2005 05:57 AM
jond
Jan 7, 2004 11:12 AM
Ideal
Jan 1, 2004 07:40 PM
