leaking clutch fluid?
where is this coming from? it looks like it would be clutch fluid, what do I need to do to fix it?
One thing though, when I put in my header about 2 months ago I had to loosen the bleeder bolt on the clutch slave and fluid came out, but my clutch has been working fine for the past 2 months.
[Modified by hitop, 4:49 AM 4/5/2003]
its coming from your clutch master cylinder. you need to replace it. pretty easy fix, just do a search for clutch master cylinder and you'll find the proceedures.
