Boost Gauge help!!!
I installed my boost gauge, its an autometer 35 psi boost gauge and doesnt have vacuum on it, the lowest it goes is 0. Anyway, I dont have a turbo, but I have one coming in, I installed the boost gauge early, well anyway what I am getting at is that hte needel doesnt move AT ALL!! is this normal? I know that I am not boosting, but I would expect a little movement. THank you.
where do you have the gauge hooked up to. If you wanted to measure manifold vacuum you could take your manifold. You should see a difference at idle and then at different throttle levels....if you care that much. Or just leave it alone until you actually need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout »</TD></TR><TR><TD CLASS="quote">where do you have the gauge hooked up to. If you wanted to measure manifold vacuum you could take your manifold. You should see a difference at idle and then at different throttle levels....if you care that much. Or just leave it alone until you actually need it.</TD></TR></TABLE>
the guage he has doesnt read vacume....i think u should get a new guage which shows both boost and vacume...and u wont see any movement in the needle bc if ure car doesnt have a turbo or sc u wont see any boost and the guage wont read anything above 0 ever
R6E6I6D
Nov 24, 2005 04:36 PM
