Questions about OBDII Smog
Old Apr 4, 2003 | 04:24 PM
dkim48's Avatar
Default Questions about OBDII Smog
I am having trouble getting my car smogged. It is a 98 ek with a swap running an obdI ecu. As far as getting smogged for a obdII car is there any difference from obdI? Do they have to plug in the code reader and is it different for obdIIa/b? Would they be able to smog it if they did not care about visual inspection? Basically what I am asking is if I took another car to get smogged for my car would they be able to pass it? Thanks in advance. I know ive been asking for hookups and I am sorry if I am bothering people but I thought this was a website designed for situations like this. Thanks again.
Old Apr 4, 2003 | 07:26 PM
94cxhybrid-T's Avatar
New User
Default Re: Questions about OBDII Smog (dkim48)
you need the obd2 ecu and all applicable sensors. For the obd and obd2 version 2 vehicles they plug into a diagnostics plug that reads directly from your computer. If they are trying to read form an Obd1 ecu it wont work and you will fail. Get all the apporpriate smog equipment and ecu from the motor you swapped in and you will pass. HTH
Old Apr 4, 2003 | 09:16 PM
dkim48's Avatar
Default Re: Questions about OBDII Smog (94cxhybrid-T)
My question is what if I take another car same year and model, maybe lx or ex civics. Is there a difference when smogging the two? If a place didnt care about the visual inspection all they cared about is if it passes will it work? Or does it have to be the same exact ecu? Thanks in advance.
Old Apr 4, 2003 | 10:46 PM
New User
it would need to be the same year make and model as your vehicle now. If oyu have a 99 you would need a 99-00 if its a civic. If its a 96-98 then you need a 96-98.
Old Apr 4, 2003 | 10:48 PM
Kamin's Avatar
you cant do that
#1 they check the plates
#2 they scan the barcode on the drivers side door jam and if the vin that comes up with the plate dosent match the vin they scan you are screwed.
and if you use your friends plates and car you will smog his for free because its all connected to the vin number.
you will not pass smog unless you are running OBDII
[Modified by Kamin, 11:49 PM 4/4/2003]
Old Apr 4, 2003 | 10:51 PM
Stripped Honda's Avatar
99-0104
Default Re: Questions about OBDII Smog (Kamin)
you cant do that
AND #3 it is a $10,000 fine for doing it (to the smog tech)
Old Apr 4, 2003 | 11:30 PM
Edubb's Avatar
Default Re: Questions about OBDII Smog (Stripped Honda)
you cant do that
not quite that high of a fine.. but they do lose liscence.. the SHOP will get the fat fine, or liscense revoked.
Old Apr 5, 2003 | 05:02 AM
b20guy's Avatar
Default Re: Questions about OBDII Smog (Edubb)
Here in TX, the fine could be as simple as $500, maybe get your license revoked, or you could get sent to Huntsville state prison. It's not worth it to me as an inspector, and I wish people wouldn't post **** like this. Do it right, or keep it on a trailer.
'00DC2
Northern California
Oct 19, 2010 06:42 PM
sloassSi
Apr 7, 2010 04:39 PM
team 15
Apr 11, 2007 07:27 PM
Ti3d in
May 8, 2004 07:06 PM
EX-T
Nov 3, 2003 08:20 AM
