check engine problem
Old Apr 4, 2003 | 03:25 PM
sbigblack02's Avatar
Default check engine problem
ok the other day me and my friend are video taping me doing 1/4 miles runs in my car but one time i accidently put it from 3rd to 2nd gear and reved the **** out of it but it was fine on wed day i did another 1/4 mile run and i got a 14.5 pretty good for stock but my check engine light came on and it says O2 sensor but sometimes it stalls out and O2 sensor doesnt really do that what do you think it might be maybe something simple like fuel filter or tune up give me your opinion
Old Apr 4, 2003 | 03:26 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: check engine problem (sbigblack02)
Old Apr 4, 2003 | 04:03 PM
01-1293's Avatar
Default Re: check engine problem (vtecvoodoo)
bent valves........chances are if you revved the **** out of it and a CEL comes on........it's not gonna be something petty.......you could have just done major $$$$ damage
Old Apr 4, 2003 | 04:40 PM
b18b98's Avatar
what was the actualy code? Do you hear any tapping or ticking noises?
Old Apr 6, 2003 | 06:41 PM
Default Re: check engine problem (b18b98)
the actually code is a 02 sensor and there is no tapping or clicking or anything like that i think that it makes it run so rich it does that it still run like a champ like nothing is wrong with it how about them itr with the strong *** b18c5
Old Apr 6, 2003 | 06:44 PM
Default Re: check engine problem (01-1293)
i think i got lucky only get one chance with that there is no problem with it or anything accept with the little hesiatation from time to time it doesnt even stall no more i just need to change that and it will be fine
Old Apr 6, 2003 | 07:13 PM
vtec.dc2's Avatar
although everything could be fine, i would get it checked so no more damage would be done, heres a calculator http://bob123e.tripod.com/askbob/Gea...Calculator.htm you can use to kinda tell rpm based on speed.
Old Apr 7, 2003 | 02:33 AM
igyloo's Avatar
a bad O2 sensor can make your car stall...changing an O2 sensor is simple too...
is your mileage getting worse?
Old Apr 7, 2003 | 02:52 AM
00MRSi's Avatar
Default Re: check engine problem (igyloo)
Check the code for sure. I would do a compression test. Hopefully you didn't bend any valves.
Old Apr 7, 2003 | 03:11 AM
Ausmith's Avatar
I would check your timing belt to make sure it didn't jump a tooth (or two or three). If you timing is off your car will stall out and can cause the O2 sensor to throw a code.
Old Apr 7, 2003 | 05:34 AM
Chubz's Avatar
i never stalled when I had 2 bad o2 sensors, chances are ID say you bent a valve if not more, do a compression test on the motor, and post the results on here
Old Apr 7, 2003 | 06:15 AM
andrewasf77's Avatar
Default Re: check engine problem (Freakzilla)
i would tend to agree. i had a couple bent valve not too long ago, i also had a cel 67 which is 02 sensor. my car would hesitate from time to time at high rpm's, but would still run strong most of the time. get it checked to be sure
Old Apr 7, 2003 | 11:19 AM
Default Re: check engine problem (andrewasf77)
yeah guys there is no bent valve if it was it wouldnt start if it started its a miracle but if it did it would be a whole lot of noise of ticking and banging which there is none its just a bad 02 sensor i got the code out of a obd 2 scanner and thats what it said everything is fine no problems
Old Apr 7, 2003 | 11:21 AM
yeah i think so i had a half a tank coming home now i got barely 3/4 but i got on it a couple of times cant help it vtec is the ****
Old Apr 7, 2003 | 11:23 AM
Dave-ROR's Avatar
It'd start as long as it wasn't too fucked up. What code ewas it exactly? (do NOT answer "o2 sensor")
Old Apr 8, 2003 | 12:16 AM
Default Re: check engine problem (dawhiteboy)
thanks yO!!! i tried to tell him that the car would stilll start even if the valves were bent, but he didnt want to listen. oh well, i guess hell take it to the shop and find out, huh?
Old Apr 8, 2003 | 11:50 AM
turbosol's Avatar
Can ya'll please use some punctuation!
Old Apr 8, 2003 | 12:40 PM
ITR 01-581's Avatar
the money shift.....i did that once but i got lucky nothing went wrong, good luck
greyejcoupe
Oct 3, 2009 10:48 AM
fmax420
19
May 7, 2007 05:26 PM
vtec-adykt
Sep 12, 2005 01:09 PM
civic_boi
Mar 28, 2004 03:06 PM
crxtreme27
Mar 26, 2003 07:04 AM
