b16b in 99 civic dx
Old Apr 3, 2003 | 03:02 PM
Chris y0!'s Avatar
Default b16b in 99 civic dx
is there anything weird you have to do?
i heard there was some issues with the b16b being setup for RHD cars, ect...
just let me know what i need, thanks.
Old Apr 3, 2003 | 03:10 PM
Unknown Member's Avatar
Default Re: b16b in 99 civic dx (Spoon Hybrid)
......................bahh get a b18c GSR or Type R...............B16B torqueless wonder..thats over priced...im not flaming but if you do get the b16b...theres nothing wrong with that.
Old Apr 3, 2003 | 03:27 PM
Chris y0!'s Avatar
Default Re: b16b in 99 civic dx (JDM IS RICE)
its not for me.
however, i did suggest the b16b to him.
why? he was going to get a b18c5, put in CTR cams, and CTR pistons. the cheapest price we could find a 99 b18c5 was almost 5 grand.
but, we found a 2000 b16b for 3700. that is more than a 2 grand difference, + 300 for the pistons, + 300 for the cams. now we are up to around 3 grand extra for the b18c5.
so the way i figure it, buy the b16b, and put in b18 crank and rods. problem solved.
Old Apr 3, 2003 | 03:29 PM
Kataku2K3's Avatar
For wiring you're just gonna be reworking your Civic's wiring harness, for Mounts all you need is a 99-2000 Si rear motor mount bracket only if you're motor happens to not come with it... It should come will all mounts so you shouldn't have to worry about that... Otherwise there is no difference with a RHD motor... Little things you may notice would be the throttle cable if it happens to come with it... I kinda gotta agree with JDM IS RICE.... I would just go with a B18C... Whether it's the USDM B18C1/C5/or JDM CR... The B18CR normally runs about the same as the B18B and difference in output is a lot... VERY NOTICABLE... A stock B18C1 EK will work a B16B EK anyday... Just my $0.02... Peace
Old Apr 3, 2003 | 03:32 PM
Kataku2K3's Avatar
Default Re: b16b in 99 civic dx (Kataku2K3)
Damn man, you beat me... hehe Oh well, that's good to know... By the way why is the CTR motor so cheap??? But that's the other thing I was originally gonna say, except the B18CR motor is pretty close so I just said screw it.... Drop a B18C crank, rods, and PCT slugs into that B16B block and you'll be set... Good Luck
Old Apr 3, 2003 | 03:37 PM
Chris y0!'s Avatar
its not really that cheap... http://www.hmotorsonline.com has b16bs for 3800 bucks... we bought one local for 3700
Old Apr 3, 2003 | 03:55 PM
Kataku2K3's Avatar
Yea I guess you're right there.... I'm glad that you didn't go through HMO... My friend's and I have had many problems with their motors... Sent cracked blocks, thrust washers falling out, etc... Oh well, just toss the 1.8L **** in that B16B casing and you'll be set.... Latez
Old Apr 3, 2003 | 04:08 PM
Chris y0!'s Avatar
i have gone through them before, no complaints here.
but then again, im local, and went down to pick my engine in person.
Old Apr 3, 2003 | 04:29 PM
HMO blows they send motors out w/ bad heads....If you look carefully you can get a 96 spec ITR for 4200.......
Old Apr 3, 2003 | 04:34 PM
Chris y0!'s Avatar
how the hell is a head "bad"?
and im in california, the engine has to be same year or newer. 96 is a no-go
Old Apr 3, 2003 | 05:04 PM
fowler!'s Avatar
There is no rewiring, just get a 99-00 Si wiring harness and it'll plug right in.
The only problem that you might have is the ecu. Depending on what year motor you get, you may need to get a jumper.
Old Apr 3, 2003 | 05:19 PM
Chris y0!'s Avatar
Default Re: b16b in 99 civic dx (fowler)
don't i have to use a USDM ECU to be smog legal anyway?
Old Apr 3, 2003 | 05:46 PM
fowler!'s Avatar
Well, if you plan on smogging it, the easiest ECU would be a 99-00 B16 ECU.
But most people ditch those soon after. I'm not sure how well that motor will smog though, being that it's JDM.
Old Apr 3, 2003 | 06:01 PM
Chris y0!'s Avatar
you can smog JDM motors as long as they have USDM manifolds and catalytic converter, and a USDM ecu.
and would a b16a ECU perform any worse than the b16b peice?
Old Apr 3, 2003 | 06:02 PM
I thought it wouldnt simply pass inspections in cali. Dont they check for a vin number?
Old Apr 3, 2003 | 06:09 PM
Chris y0!'s Avatar
it doesn't pass inspection.
you have to go to a california state ref, have them check out everything, actually smog the car, then give you a sticker showing that you did everything right, and then you can smog the car at any 76 station on a street corner.
Old Apr 3, 2003 | 11:30 PM
Jackson's Avatar
Do what Fowler said. Also, you know you can unplug ecu's. Just the p2t ecu for smog and put in the pct ecu any other time.
Old May 20, 2003 | 11:01 AM
JICB16B's Avatar
Default Re: b16b in 99 civic dx (Chris y0!)
i just did the b16b in to my 2000 civic ex and it was easy no major wiring problems just had to extend some wires on my ex harness no big deal
EuroR_TSX
Nov 22, 2006 11:43 AM
BlackOnBlackTeggie
Nov 8, 2004 11:56 AM
h22dx
Oct 19, 2004 06:37 PM
redlinetuning
10
Jan 29, 2004 05:56 AM
