Cam Shaft Questions
Old Apr 3, 2003 | 01:48 PM
ramz7887's Avatar
Default Cam Shaft Questions
I wanted to know if a cam shaft upgrade is a drop in or do i have to change the valve springs, cam gears, or other things? I want to put in a new zex cam shaft for a 96-00 sohc. I also wanted to know what the instalition might run me?
Old Apr 3, 2003 | 01:56 PM
lazy bum shaughn's Avatar
Default Re: Cam Shaft Questions (ramz7887)
If you're going to rev high, you'd want to change out the valve springs and retainers, and to adjust your cam timing you need a cam gear.
Old Apr 3, 2003 | 07:14 PM
ramz7887's Avatar
Can i get by with just the cam shaft right now and then later change the springs,cam gear, and retainer? It is a lot of money for me so i can only do a little at a time. Also do you know of any other good sohc's? So far the zex looks good, while at least the price. I think it is 280.
Old Apr 3, 2003 | 07:15 PM
.RTErnie's Avatar
save yer money and do it right. k?
Old Apr 3, 2003 | 07:17 PM
ramz7887's Avatar
Thanks, i guess i will have to first get a skunk intake manifold and then save up some money for a good cam system.
Old Apr 3, 2003 | 07:18 PM
kommon_sense's Avatar
Default Re: Cam Shaft Questions (RTErnie)
I'd recommend doing the cam and cam gear at the same time. You should not need a new valvetrain unless you intend to raise your rev limit.
kixcrx
Jan 3, 2008 03:16 AM
Topdawgg
Oct 31, 2006 04:48 PM
sohctodohc
11
Jun 5, 2005 07:47 PM
ramz7887
Mar 31, 2003 01:59 PM
