OBD2 to OBD1 Conversion - Secondary O2
Old Apr 3, 2003 | 07:25 AM
ajchen's Avatar
Default OBD2 to OBD1 Conversion - Secondary O2
trying to figure out how much i will gain from switching over to the dark side... i have a 2000 GSR right now which i feel is really limited by the emissions standards of OBD2.
as of right now, i am running a carsound cat with secondary O2 bung in it. i am throwing a CEL 67 - catalyst below threshold... i think its because the carsound isnt filtering out as much as it should, so thats why i have the code. i know that OBD1 cars only have one o2 sensor at the header. my question is:
if i switch from obd2 to obd1 with a chipped p28, will i still throw a CEL 67? or will it just not recognize my secondary O2 and therefore i will be code free?
thanks in advance....
Old Apr 3, 2003 | 07:42 AM
Chris N's Avatar
Default Re: OBD2 to OBD1 Conversion - Secondary O2 (ajchen)
OBD1 won't recognize the secondary o2.
So, you could unplug the secondary o2 and plug the bung on the cat. Or, just leave it and the ecu won't even acknowlege it.
[Modified by Chris N, 10:43 AM 4/3/2003]
Old Apr 3, 2003 | 07:51 AM
ajchen's Avatar
Default Re: OBD2 to OBD1 Conversion - Secondary O2 (Chris N)
NICE. thats what i like to hear. so it wont throw a code right?
has anyone converted to OBD1 and also run a VAFC on it? how complicated is the wiring situation when you also have the conversion harness?
Old Apr 3, 2003 | 08:15 AM
Chris N's Avatar
Andrew-
No code.
Not sure about the VAFC and OBD2-1 harness. Should work fine, you just have to know which wire is which...
If the search was up, I'd help out. But...
Old Apr 3, 2003 | 08:24 AM
Aaron M's Avatar
good info
ill be doing the same, obd2-1 with a chipped ecu
724chris
Jan 23, 2010 07:04 PM
jdb2527
Aug 11, 2007 11:45 AM
fanoftheb00st
Jun 16, 2007 08:27 PM
gsr_to_the_MAX
Jul 26, 2005 06:12 PM
BI8B
Nov 21, 2003 02:33 PM
