itr pistons
Old Apr 2, 2003 | 07:09 PM
CivicHB_92's Avatar
Default itr pistons
hey guys,
im thinking of buying a set of itr pistons off somone and put them in to my 1995 integra ls motor, but im wondering if anyone done it before, if so, what was the out come? and was it worth it?
thanks in advance.
Old Apr 2, 2003 | 07:38 PM
ucacrx's Avatar
Default Re: itr pistons (CivicHB_92)
likewise
would you happen to have the part # for the itr pistons/rings??
thanks
Old Apr 2, 2003 | 07:41 PM
renzema's Avatar
Default Re: itr pistons (ucacrx)
I've been looking into this for a while.
I was told that B16a2 are a better piston to use
1) you don't have to machine the rod to get them to fit.
2) they have a higher compersion ratio.
Old Apr 2, 2003 | 07:54 PM
lazy bum shaughn's Avatar
Default Re: itr pistons (renzema)
I thought you needed to machine the rod to make them fit.
Old Apr 2, 2003 | 08:53 PM
Nice_Dc2r's Avatar
Default Re: itr pistons (lazy bum shaughn)
b16a2 pistons are a direct fit
Old Apr 3, 2003 | 03:28 AM
CivicHB_92's Avatar
Default Re: itr pistons (nice_eg)
if i were to use the itr pistons, could i use my stock b18b rods or do i have to go with itr rods too? same question with the b16a2 pistons, can i use my stock b18b rods or do i have to go with the b16a2 rods?
im new at this....so im still lost...but learning!
Old Apr 3, 2003 | 03:58 AM
b19coupe's Avatar
If you use GSR/ITR/CTR pistons, the small end of the B18B rod needs to be machined to accept them. I have run both ITR and CTR pistons in an LS/VTEC with good results.
I don't know for sure about B16A2 pistons, but it appears that the consensus is that they are a direct replacement, no modification to the rods necessary.
B16beatdown
Mar 17, 2004 11:15 AM
89JDMcrx
Oct 24, 2003 07:32 PM
ggangtong81
Sep 19, 2003 12:44 PM
DOHCon15s
Apr 11, 2003 06:46 AM
Screamer
Jul 29, 2002 07:37 AM
