LS/B20 VTEC question
Old Apr 2, 2003 | 04:39 PM
lazy bum shaughn's Avatar
Default LS/B20 VTEC question
Well to my understanding the reason why LS/B20 VTEC motors blow is because of the cylinders cracking, due to high revving which the block wasn't meant to handle.
Has anyone had their block resleeved(iron ductile) and still had problems?
Thanks.
Old Apr 2, 2003 | 04:48 PM
tinkerbell's Avatar
Default Re: LS/B20 VTEC question (lazy bum shaughn)
Thanks.
it is un-tuned engines DETONATING that usually cracks sleeves, not high RPM...
(although detonation may be likely to occur at high RPM)
high revving usually cracks rods and bends valves, esp. on a mis-shift...
t..
Old Apr 2, 2003 | 04:50 PM
Ohh, I didn't know that. What would be a cheap way to manage an LS block, resleeved to 84mm bore, JE 12:1 pistons, probably Z10 block girdle...what type of ECU?
Hondata is cool, but I hear it's like 2000 bucks!
Old Apr 2, 2003 | 05:38 PM
dfoxengr's Avatar
hondata is only 800-900 with everything u need.
u can use a stock computer though and VAFC though
Old Apr 2, 2003 | 05:44 PM
Default Re: LS/B20 VTEC question (hybridvteceg)
So do you guys think it would be safe to just use stock B20 sleeves with some high compression pistons as long as it's tuned?
Old Apr 2, 2003 | 05:45 PM
dfoxengr's Avatar
yes..no problem
Old Apr 2, 2003 | 05:48 PM
thanks for the replies guys..bump.
I would also like to know your guys' imputs on block girdles.
Old Apr 2, 2003 | 05:49 PM
dfoxengr's Avatar
unnecessary
Old Apr 2, 2003 | 05:51 PM
unnecessary
Well I would think they are because Honda put them on stock GSR/Type R, which have a better rod/stroke ratio than LS/B20.
dfoxengr's Avatar
u thought wrong.
Old Apr 2, 2003 | 05:52 PM
dfoxengr's Avatar
r:s has nothing to do with the necessity of a girdle
Old Apr 2, 2003 | 05:54 PM
tinkerbell's Avatar
elaborate?
Old Apr 2, 2003 | 05:55 PM
What is the purpose of a block girdle then?
Old Apr 2, 2003 | 05:56 PM
dfoxengr's Avatar
gives some assurance, but is not TOTALLY NECESSARY
Old Apr 2, 2003 | 05:57 PM
tinkerbell's Avatar
assurance of what exactly?
Old Apr 2, 2003 | 05:59 PM
dfoxengr's Avatar
Default Re: LS/B20 VTEC question (tinkerbell)
their motors durability, thats y people buy them isnt it, not so u can see howcool it looks.
Old Apr 2, 2003 | 06:05 PM
tinkerbell's Avatar
if the block guard is for reliability why do you say it is TOTALLY UNNECESSARY ??
Old Apr 2, 2003 | 06:10 PM
dfoxengr's Avatar
because i said u dont need it, some poeple think u do, but its unnecessary
Old Apr 2, 2003 | 06:18 PM
tinkerbell's Avatar
LOL!
sorry to have questioned your reasoning Derek!
t..
Old Apr 2, 2003 | 06:32 PM
I was also wondering what valve reliefs are?
Old Apr 2, 2003 | 06:51 PM
b-b-bump.
Old Apr 2, 2003 | 07:57 PM
Last bump for the night, what are valve reliefs?
Old Apr 2, 2003 | 08:02 PM
tinkerbell's Avatar
see those 4 semi circles?
they are where the valves have room to open when the piston is almost at the top of its stoke...
t..
Old Apr 2, 2003 | 08:09 PM
So the valve reliefs are those semi-circles on the pistons, what do people mean when they say they have to cut them or something when going B20/VTEC?
Old Apr 2, 2003 | 08:11 PM
tinkerbell's Avatar
does the B20/LS have the same size valves as a VTEC engine?
find out...
t..
