Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Displacement vs. weight
Old Apr 2, 2003 | 04:10 PM
Eee Pee's Avatar
Default Displacement vs. weight
Here is an interesting thought to pounder: (to me anyways)
EP rules state a cars minimum weight is determined by displacement x 1.05. No car shall be under 1600lbs. The 1.6 (Si motor) cars must weigh 1680. The 1.5 (DX motor) cars can weigh 1575 (but need 25 lbs for minimum weight, which can be placed anywhere). Which would you do? Thats 80 pounds. At what point does HP have the advantage? Autocrossing anyways.
And of course money is speed...
Old Apr 2, 2003 | 04:15 PM
.RJ's Avatar
.RJ
Default Re: Displacement vs. weight (Eee Pee)
I'd take the D-series motor....
The B16's are pretty gutless till 5000 rpm.
Old Apr 2, 2003 | 04:18 PM
Eee Pee's Avatar
Default Re: Displacement vs. weight (.RJ)
Ahhh, by Si motor I meant the D16...
Old Apr 2, 2003 | 04:30 PM
preparedcivic's Avatar
The answer is it depends.
How much weight have you gotten out of the car? My 3G 86 Si, minus ballast, gas and the rollbar is around 1590. The windshield is still OEM glass, but the door window are out, and the hatch and rears are lexan. To get it any lighter would take serious effort. Yours is a 5th gen? You got more metal than me; I'd say it would be tough to get below mid 1600's, so you might as well stay with the D16, and if weight is needed add it in advantageous locations.
Old Apr 2, 2003 | 08:57 PM
SUPERAUTOBACS's Avatar
I'd go with the lighter 1.5 DX motor and place the 25lbs of ballast to the lowest part of the car. And you can probably play around to find out which location works the best accroding to course design.
B18C5-EH2
222
May 15, 2013 12:34 PM
TEAM ASSASSIN SI
Mar 7, 2011 10:12 PM
aeenox
Honda Civic (2006 - 2015)
Sep 29, 2006 09:13 PM
chrisCNL
Sep 8, 2004 12:04 PM
K20 EG
Feb 19, 2003 09:34 PM
